Jensen Vm9214 Car Video Player Logo
Question about Jensen Vm9214 Car Video Player
Jensen vm9214 when i hook my indash to battery only the src button is red it wont turn on t
Larry Spears
  • 625 Answers
Did you connect the power, ground and accessory? When doing a bench test for operation, these wires need to be connected.
Posted on Oct 01, 2012
  • Anonymous Oct 01, 2012
    hey i found my problem. i actually bought this indash two days ago from onlne. the problem is that the port behind the indash the one that the harness goes inside. on the port there are 16 pins. the accesory pin is halfway brokken. so i had to connect a wire to the pin to make it work. thanks
5 Related Answers
Ern Dissla
SOURCE: jensen vm9311 dvd indash volume is loud when i turn on car
Heres the best way to fix; Quote from manual "Programmable Turn-On Volume (Pg.12) This feature allows the user to select a turn-on colume setting regardless of the colume setting prior to turning the unit off. To program a specific volume level, push and hold the VOL/LOC/DV know (6) while the yellow volume bar is displayed on the screen. The unit will beep two times to confirm your turn-on volume setting." Ah i had the same problem. I turned to the manual and it worked for me :) Good Luck, Ern
Posted on Nov 30, 2006
Anonymous
SOURCE: jensen indash cd dvd player
its easy , I do it all the time . . [email protected]
Posted on May 19, 2008
coreman021
  • 13 Answers
SOURCE: wont turn on
check your fuses and all connections, make sure you have a good ground to the stereo and make sure the yellow and red positive wires are not loose!
Posted on Jul 31, 2008
Anonymous
  • 1157 Answers
SOURCE: i have a jensen vm9214
Hi timkilian,
If your iPod won't play, it might caused by some setting on your Jensen vm9214. Also please ensure that your iPod has the latest Apple firmware to avoid any connectivity issue. Please visit this link for additional information on how to operate the iPod on the Jensen VM9214.
Hope it helps.
Thank you for using FixYa.
Posted on Mar 30, 2011
Anonymous
SOURCE: dvd screen comes half way
sounds like the mechanism for the radio got some dirt in it, or the gears are damaged. a little sand or coffee would do the job. you could try gently helping it out but if you pull too hard it could break so be careful.
Posted on Jun 16, 2011
1helpful
Why is my My Jensen VM9214 stuck on camera mode
Check your wires, theres a wire for the reverse if your going to use a back up camera, if not do not connect it, you may have had it connected through a speaker wire, if so then thats your issue and once you wire it up right it wont do that any more, had the same issue and thats what fixed it hope this helps
2helpful
Red light comes on but the unit wount turn on
The red light is associated with the memory (constant 12 volt power). You also need switched 12 volt power (power with key turned to accessory)for the unit to turn on. If you installed the system yourself, you are looking for 12 volts on the red wire of the Jensen unit. If power exists at the unit, check the fuse of the unit and the fuse of the vehcile.
When i turn on my indash dvd keenwood player it jus says standby and nothing works
Press the SRC button to turn unit on. The SRC button allows you to navigate between input sources,i.e. tuner, cd, aux, etc. Press and hold SRC button for second to turn unit off ( it will display standby).
1helpful
How to hook up Jensens Vm 9312 car stereo indash
how do you make the navigation work on the jensen VM9312
Jensen VM9312
To wich cable do i connect the pink park cable from my jensen in dash vm9311ts
you have a indash tv
all u do is hook the pink wire up to the grownd wire and it will play while your driving
Step by step instructions to hook up a jensen cd/dvd indash car stereo ]
Try Googleing the user's manual. I found one for my Pioneer and also for a sony Grand Wvega that way.
2answers
Screen doesnt turn on
try selecting the dvd or tv modes ... if that doesn't help , reset the system and start all over.
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
