Did you clean the machine? When you went through the cleaning steps it should have cleared the clean light. I will tell you what to push first Remove the front cover. If the machine is operating then push and release the harvest button. When the machine completes the Harvest cycle it will stop. Push and release the OFF button. Push and release the clean button. The yellow clean light will blink and display will show C. The machine will drain the reservoir and refill it. Go into the next step when the reservoir has filled. Allow the the ice machine to circulate water for at lest 10 minutes. Normally this is when you would add your cleaning solution but i take it you have already cleaned the machine. Now push and release the Clean button again. The yellow Clean light will be on continuously and the machine will drain and refill the reservoir repeatedly to purge out the ice machine. Now Allow the drain and refill process to continue for at least 20 minutes. Now Push and release the OFF button. The clean cycle will stop and the display will show 0. Now push and release the on button. This should have cleared the yellow clean light. Now with that out of the way if it did not clear it then you will need to replace the control board. The machine will steel make ice with no problem and you just clean the machine every 6 mounts. The yellow clean light is just to remind you that it is time to clean the system. The board is quite costly.
you can remove the plastic siphon from the machine and clean it. it sits between the bleach and fabric softener reservoirs just squeeze at the ends and it pulls up and out. check the holes and clean with hot water.
I'm willing to try this to clean the mold out of the steamer container and possibly the rest of the attachments:
1. Empty the water reservoir completely.
2. Place 20 mL of CLR or bleach into the reservoir.
3. Fill the reservoir with hot water.
4. Shake the reservoir to mix and let stand for about 1 hour.
5. Empty the reservoir completely.
6. Rinse the reservoir 3 or 4 times with cold water.
7. Fill the reservoir with distilled water.
8. Run the steamer into the ventilated air a couple of times to ensure that there is no CLR or bleach residue on the evaporation elements. Thus, there will be no bleach on your cloths.
I have the same problem and will try this out tomorrow. I will tell you how it turns out.
Hiya Vanch... disconnect the electric.. remove the lid screws at the rear.. slide from the front to the back with lid.
Depress the tab at the top of the drawer "gently" whilst easing the drawer from the machine.
Refit lid.. connect up to electric.. Sorted!!
Thanks So much
your welcome
