Question about Kodak EasyShare M320 Digital Camera
Kodak easyshare m320 charge light is green, but not charged
I charged my camera all night on different wall sockets, the light is green when i have it plugged up. when i unplug it and turn it on, the light turns red and the camera turns back off saying it has a dead battery
    Genius:
  • Kodak Master
  • 1,019 Answers
Hello Dead Battery, Well this sounds pretty easy compared to most questions I get. If the camera says the battery is dead, then the battery is dead !! the problem with batteries is they loose their capacity over time. The charger can not put any more in it and says it is charged. Just get a new one and give it a full charge and this should do the trick.
Best Regards, Russell
Posted on Jan 24, 2013
5 Suggested Answers
Anonymous
SOURCE: My Kodak EasyShare DX4530 camera dock not charging batteries.
There was an issue with the 4000 series and the NiCd batteries I remember that had to do with the contacts in the camera.  The charging circuit is in the camera so you have to make sure that the battery contacts are clean, both on the battery and in the camera.
Posted on Jan 26, 2009
Anonymous
SOURCE: Kodak Z700 not firing up
Same problem as described above. Fresh batteries, turn it on, see the Kodak screen for a second, then it just turns off. I found that if you swith it to the favorites icon (the only one below the Off position) it stays on and I can review photos. But no taking new photos! Help!!!
Posted on Jun 02, 2009
Anonymous
  • 151 Answers
SOURCE: Kodak EASYSHARE M1063 won't turn on
For this problem try doing the following:
  • remove the battery and the memory card
  • clean the metal copper on the battery
  • power on the camera without the memory card
If problem persist call the 18002356325 for technical support for KODAK Digital cameras
Thanks
Hope this will help
Posted on Sep 23, 2009
leepania
Pania Lee
  • 1099 Answers
SOURCE: my kodak easyshare M320 isn't charging
Possible solutions:
Remember you need to turn the camera on when transferring.
Try a different USB outlet
Try a different cable
Try a different computer.
If all fails please contact KODAK in order to arrange a repair or order a new cable. Remember your USB cable is covered under the same warranty as your camera, so remember your serial number when calling:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Jan 28, 2010
lock123
Andrea Lock
  • 6831 Answers
SOURCE: kodak easyshare ls743. lens wont retract. camera error #E45 shows on screen. battery is fully charged.
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Dec 14, 2010
Will not charge
Kodak camera wont charge? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 1, 2011 - My Kodak EasyShare M580 digital camera wont charge. I have the USB charger, but when I plug everything in, the charging light wont light up, ... Kodak Easyshare camera will not charge?
Mar 27, 2014
My kodak easyshare m580 WILL NOT charge?
Mar 14, 2012
Kodak Easyshare M580 Not Responding To Charger?
Dec 7, 2011
My kodak easyshare m580 will not charge?
Apr 16, 2011
More results from answers.yahoo.com
Nov 29, 2015 | Kodak Easyshare M580 Digital Camera
Kodak easyshare m320 froze and won't turn on
Send it back to Kodak, these models are nothing but trouble, far to many customer complaints, Made in China and not made very well, not dependable, Try a better brand. Kodak has seen better days with their products. Buyer Beware
Oct 15, 2012 | Kodak EasyShare M320 Digital Camera
My kodak easyshare M320 isn't charging
I believe your camera has a specific battery and battery charger? You may need to purchase a new one. Even rechargeable batteries need to be replaced after awhile. Try purchasing a new kit (battery and battery charger) and see if that works!
Something like this:
http://www.amazon.com/Kodak-M320-Digital-Camera-Accessory/dp/B004J5C2JO
Hope this helps!
Jul 26, 2011 | Kodak EasyShare M320 Digital Camera
My kodak easy share m320 will not charge with the wall plg or the usb plug. when i plug it in the green light will come on for a few min but then go out. ive left it plugged in overnite to no avail. any...
Rechargeable batteries have a finite life. Yours may have come to the end and need to be replaced. Replacing them is probably the only way to test this.
Lithium batteries in particular can have their lives shortened by being run completely flat, so that is something to avoid.
Oct 30, 2010 | Kodak EasyShare M320 Digital Camera
My kodak easyshare M320 isn't charging with the USB cord and my camera won't turn on either because there's literally zero battery left.
Possible solutions:
Jan 28, 2010 | Kodak EasyShare M320 Digital Camera
Got a brand new M320. Charged up the battery and
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 02, 2010 | Kodak EasyShare M320 Digital Camera
My Kodak Easyshare V1233 will only power up when plugged into the wall charger. Even after staying on the charger it will not power on unless plugged in.
Kodak has 3 types of charger that can be connected to a wall socket
USB AC Adapter - is especially useful when traveling, away from your computer, or just plain on-the-go. Connect your camera's USB cable to the adapter and plug it into a wall outlet to conveniently charge your camera.
5V AC Adapter - Provides in-camera charging for all KODAK EASYSHARE M and V Series Digital Cameras
Input: AC 100-240 V 50/60 Hz Output : DC 5.0 V
3V AC Adapter - Provides direct power to your camera but it will not charge the camera battery
Input: AC 100-240 V 50/60 Hz Output : DC 3.0 V
* You need to check the type of adapter your using. If your using the 5V AC adapter or USB adapter and the camera won't charge the battery contact kodak support line 1 800 235 6325 (23KODAK) for possible repair.
Nov 16, 2009 | Kodak Easyshare V1233 12.1MP Digital...
When i go to charge my kodak M863 camera (in the wall or by USB) the green light flashes and then the red light blinks 3 times. please help this is the first time charging my camera.
You can used the USB cable to charged the camera, But some of the M863 camera will not take charged usign the USB cable., I strongy suggest used the AC adaptor just make sure the AC adaptor is 5V ac adaptor it will only charged using the 5V adaptor., About the flashing green it indicates camera is charging just wait for the solid green light it means it fully charged
You may purchased also a special charger for your battery(KLIC-7001)- cahrer model is K8600-C. i think the price of this charger is around $29.00
Nov 14, 2009 | Kodak EasyShare M863 Digital Camera
Kodak EasyShare M320 Digital Camera Logo
193 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
