Canon IR 105 Digital Copier RECONDITIONED Logo
JULIO Posted on Sep 29, 2012
How do I find the main charger on a canon ir 105?
Code E000065-0000 leads me to check on the main charger. But I dont know where to find it in the machine. Please advice anyone. Thank you
babak khosroshahi
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 28, 2014
babak khosroshahi
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
289
Points
Check & clean charger
raven_neece
Level 1:
New Friend:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Sep 29, 2012
raven_neece
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
19
Questions
Helped
5642
Points
58
Cannon printer c5030 code E000532-0002 what do it means? ?
Stapler assembly issue
https://printcopy.info/?l=en&mod=erc&brand=Canon&model=iR%20Advance%20C5030&page=34
  • Code: E532-0002
  • Description: STP Move Motor fails to move from HP
    At initial rotation, when the Motor rotates for specified period of time and cannot move from HP, it is detected as an error if the same symptom occurs again after the first retry.
  • Remedy: 1. Check if the Motor (M1) Connector is physically removed. 2. Check if the Motor failure occurs. 3. Check if the Stapler Move HP Sensor (S10) Connector is physically removed. 4. Check if the Stapler Move HP Sensor (S10) failure occurs.
https://www.justanswer.com/printers/4mgs2-canon-c5045-error-message-e000532-0001.html
http://www.copytechnet.com/forums/canon/43109-canon-ir-105-e000532-002-a.html
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Nov 22, 2014 - 3 posts - ā€Ž2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion Ā· Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
What is solution for E240 in canon ir 105??
E240 is a communication fault between the DCC and main controller.
Several cases were reported where the HDD was causing this. Symptoms included: Control panel locking up, machine suddenly powering off, and E240.
One case reported was resolved by replacing the main controller.
Perform HD-CHECK in service mode. If this doesn't resolve the problem replace the HDD.
1helpful
E000225 0001
Oh, it looks like your ImageRunner's fixer unit (the heater thermistor it uses to regulate temperature) burned out or disconnected on you. http://canon-ir-6000.blogspot.com/2009/02/e000-main-cause-main-thermistor-th1-has.html
Find that little sensor leading up to the coils and replace it.
Otherwise, say that again in just Hindi?
2answers
11helpful
2answers
Canon iR 3100CN Error code E000732-0001
E732 Reader communication error
0001 DDI-S communication error Check on connection between the reader controller PCB and the main controller PCB, Check on the
reader power supply
Hope that helped!
53helpful
6answers
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
1helpful
2answers
Where can i find pc drivers for canon ir 105
Go to www.canonusa.com and navigate to support and drivers. Then select your product and download what you need.
old marine
old marine
ZJ Limited
ZJ Limited
