When I turn my 2000 Toyota Corolla on, the headlight turn on without my cutting them on. When I flip the headlight switch on the headlights turn off. Also they stay on during the day and off at night. I changed the headlight switch and the headlights themselves and it's still doing the same problem. How do I fix it?
SOURCE: Need to change headlight on 1998 Toyota Corolla
Unless you have really small hands, you are going to have to unbolt the battewry bracket, and move the battery backwards as far as possible. Then you will be able to see the connection where the bulb socket mounts behind the headlamp. There are 2 different styles of bulbs that you may find...
If you see a large rubber ring, remove it, and undo the silver clip to extract the bulb.
If the wiring/socket goes directly into the back of the headlamp, simply twist the socket 1/4 turn, and pull it out.
SOURCE: Headlights not working, fuses good...
there sounds like a deffinant short some where. you'll need someone that knows electrical to find the sourse. sorry
SOURCE: Corolla 99 headlights
The car is equipped with Daytime running lights so it will always be on...to turn it off you must go in the hood and on the right side next to the engine air filter and fuse box, there is two smaller fuze boxes and the first one going from down to up direction labels DRL left and DRL right which are two fuses 10A or so take them off and they will not come on!
SOURCE: Headlights turn on by themselves when vehicle is parked.
Do you have auto lights when it gets dark out? When they come on is it in a parking garage or home garage where its dark If so chances are your switch/relay unit is bad. (or do they come on in daylight too)?
