Question about Alphasonik PSW112C Alpha 100 Series 12" 460 Watts Subwoofer Car Speaker
How can i get my speakers fixed
I was going down the freeway one day an my speakers just went out. i thought it was my amp so i went an had it check, they said it wasn't my amp. so they check my subs it was the subs.
Posted by lee fairley on
Michael Lee
  • 23 Answers
It may not be the subs, but the amp could have caused the subs blowing/freezing up. If an amp is clipped it will send to much voltage to the subs, thus blowing the subs. Clipping the amp is when someone sets the gains on the amp to higher than the sub can handle. Find this out before you buy new subs. If not, you may have blown subs again.
Posted on Oct 18, 2012
Hi i have a problem with my 2000 mazda 626 LX 4 cyl .. The other day(sept 5, 2011) i had a oil change & replaced my air filter. Then a couple days i replaced all 4 spark plugs. Thought it would fix...
you need a shop to check it over, before you replace more parts. The fuel filter may need to be replaced, but it wont fix your problem, its under the hood, near the LF wheel.
Sep 13, 2011 | 2000 Mazda 626
Durabrand Home Theater System Model HT-3917. It was playing ok a little crackle from the front side speakers for a couple days now and it just went off. I checked the fuse no,I checked the power strip and...
You (we) still don't know if the speaker or electronics are at fault. Swap the speakers left-to-right. Use test tones to test all channels. Could be a loose speaker wire, too.
Jul 24, 2011 | Durabrand HT-3915 System
Two days ago my car died on the freeway off ramp, took about 3-4 tries to restart it and after going about 100 ft it died again. I managed to get it started and drove 2 miles to get home. The car spent...
I'd look for issues when it is not running-does it get spark? When it completely dies, and you try to start it, look at the tachometer, see if it moves-if it does, you have spark. Then you know it is a fuel problem, either the fuel pump is going/gone (can be checked when not running by checking fuel pressure at the rail when cranking)-or it might be as simple as the fuel filter (that'd be nice)-I personally think the IAC (idle air controller) had nothing to do with your problem and your mechanic just threw that part at it-I'd be more inclined to think it was a Mass Air Pressure sensor (MAP) if I was going to suspect something that might cause your problem, an IAC would not do that-is the MAP plugged in?
No matter what, the fuel pressure is easy to check, the filter easy to replace-and the MAP would set a Check Engine Light.
Jan 07, 2011 | 1998 Honda Accord
2000 Nissan Maxima Battery & Brake Light On
I thought this was free support. Apparently I was wrong. How did I fix it? Easy, I broke down on the freeway and got towed home on a flatbed! That was easy!!
Jul 30, 2008 | 2000 Nissan Maxima
No power
in standby mode press the following:-
stadium------night-------dsp off------club.
the system will return to its original status.
Apr 23, 2008 | RCA RT2500 System
LED Light is on, but no sound from sub at all.. Have double backed on all wires but still nothing! HELP!!
if you change amps and it goes on protection the speakers are blown causing the amp to protect try changing speakers
Mar 24, 2008 | Car Audio & Video
If you've overheated it a number of times, it's possible that you've damaged the amp and it's trying to protect itself even though it's too late. Try disconnecting the sub from the amp. If there's no change, then there's a problem within the amp. It could be a thermal switch or possibly a stressed amplifier module.
Hope this helps. Good Luck!!
Mar 21, 2008 | Car Audio & Video
Red lioght keeps comming on
Make sure ohm load is not too low, I think that amp is 2ohms/ch and 4ohms bridged minimum.
Oct 29, 2007 | Sony XM-1252GTR Car Audio Amplifier
Amplifier
First problem is that if you ever have a problem with anything electronic you dont ignore it going on and off or you dont hit it to get it to start working. Thats a true indicator that something is wrong and/or somethings about to break and take everything with it. When it first started to go on and off You could have made sure that the speaker lines were not loose or touching one another or another big problem like this is the speaker wires and how they are ran thru the vehicle sometimes the vibration will rub off the insulation and /or pinch the wire and short it out agains the chassis of the vehicle. The best way for you to trouble shoot this is to first have someone check the speakers and lines. Make sure the inputs are good and disconnect the output lines(speakers wires) from the amp and put a dc meter on one of the outputsw. And have someone turn o0n the power. If theres any dc there for even a spit sec then the amp has blow output devices and probably also bad drivers and predrivers. At this point find out how much your local repair person would charge you for an estamate. or contact Boss at 323.890.3700 ext. 2770 Good Luck
Apr 17, 2006 | Boss Riot 2500D Car Audio Amplifier
Alphasonik PSW112C Alpha 100 Series 12" 460 Watts Subwoofer Car Speaker Logo
71 people viewed this question
Top Alphasonik Car Audio & Video Experts
Marvin
Marvin
Are you an Alphasonik Car Audio and Video Expert? Answer questions, earn points and help others
