Bought with cd/dvd drive in bits and cant find schematics to put back together.
Optical drive should be one piece, and slide right in.
Here is the notebootk manual in PDF.
http://h10032.www1.hp.com/ctg/Manual/c02985882.pdf
The rest are here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&lc=en&dlc=en&document=&product=3946785
SOURCE: Drivers for Compaq presario cq60-200el
Below is a link to a free program called RadarSync...Install it and then scan your pc, it will find updates or missing drivers. It will then give you an option to download said drivers free of charge.
http://www.radarsync.com/
Good luck, and thank you for choosing Fixya! Please leave a positive rating if this helps with your problem.
SOURCE: Compaq Presario CQ60 recovery disc how to use
insert the disc into the drive, restart the computer.If it doesn't boot from disc, restart again.
As it restarts, press and hold F8(may be F2 or F12 depending on the settings)until the boot options screen appears. Using the arrow up/down keys select drive "d" or what ever drive letter represents the drive you put the disc into.
It will now(or should) continue to boot from the disc, follow the onscreen instructions to restore.
SOURCE: My presario Cq60 cd/dvd drive not working. Driver
From your description I understand that the DVD drive is not working and you have code 19 error in device manager.
Do not worry, run the following fix on the pc and then restart the notebook.
http://www.techiesspot.com/filez/cddvdfix.reg
SOURCE: my compaq presario CQ60 is overheating how do i
the overheating could happend for the following reasons:
-check that the fan is working and the vents are not blocked. do not put the laptop on the sofa or the bed. glass may also increase the temperature.
-check that the bios is up to date. maybe the fan is not working fast enough
-are you playing a lot of games or using an application(like video editing) that uses the graphics card intensively?
download this
http://www.almico.com/sfdownload.php
to check your fan speed and temperature of your laptop
