Marantz SR-5200 Receiver Logo
Anonymous Posted on Sep 28, 2012
CS4228A burns after replacment
After replacment of CS4228A on DSP board, it burns after several times powering receiver on/off. VD pin of CS4228A gets ~100 ohm. Power supply looks correct +5v stable.
Anonymous
Level 3:
  • Master 5,807 Answers
  • Posted on Sep 29, 2012
Anonymous
Master
Level 3:
Answers
5807
Questions
0
Helped
273351
Points
13914
Hi
Martynas Z
CS4228A on DSP board can be overdriven on the inputs
CS4228A on DSP board can have shorted loads on the output
Check also the board (might be burnt also)
Here is block diagram for you:
Check components around it thoroughly.
Let us know how you make it out.
  • 1 more comment
  • Anonymous Oct 02, 2012
    First of all the main problem with receiver was that FL channel was noisy. I found that CS4391 is defective. Sound from other channels was ok. After I changed CS4391 noise from FL channel was gone. But no sound from any of cahnnels. I noticed tha CS4228a heats up. So after i changed it everything was ok, but just for several timer tu turn on and off. I didn't find any defective componenets around cs4228a. I ordered another one chip, but because i didnt' find any probelms I'm afraid to burn one more :(
    good luck and be safe always.
  • Stamatis Avlonitis Jun 13, 2014
    Martynas, did you finally fixed this issue? I have exactly the same symptoms but had only replaced 4392 only till now. I doubt if it is worthy to continue with 4228
My Onkyo TX-SV-919THX receiver shows DSP error on display, I want to replace DSP board, from where can I get DSP board?
Hello Raju, We cannot sell any parts directly to a customer. The unit would have to go in for service or you can look into our trade in program if the unit is out of warranty. For more information on trade in you can contact product support at 800-229-1687 x3. Thanks, FJD
No sound for onkyo receiver tx nr709
most likely your digital board is bad. Try this: turn the unit on, hold the display button and press power, there should be some front panel buttons that are + and -, press these to cycle through showing the different firmware versions. It should start out at MAIN the next one should be DSP, if the DSP shows nothing but ?????????, than Q3001 on the digital board is bad and you will need to replace the board
1helpful
2answers
When I turn on the receiver it displays check pow5, then returns to standby mode. SR7001 Marantz Unit
I have the problem of check POW5 too and have the similar procedure taken several times but it doesn't help. What actually problem I have encountered? Or the quality of this brand is not reliable? Does any body help?
3helpful
No audio output
THE FIX - to audio problems that persist with the VSX-29TX and others using the AWX7272 DSP board is to replace the ROM on the DSP. My unit started failing on and off after 10 years of use! The intermittent DSP board is an Extremely Common and irritating Problem for this model! The replacement IC,(2) resistors + shipping and handling totaled $49.65 and my unit is finally fixed correctly! Don't believe other posts that you can get away with re-soldering; it will continue to fail again and again! Details of fix are:
Replacement for the old Pioneer ROM located at location IC 9374, should be done with the part PD6381A from Pioneer Electronics. You will also need to move (relocate) the 2 resistors (0 Ohm resistors) located at R9372 and R9371 to locations R9374 and R9373.
This component update applies to DSP boards marked as AWX7433, AWX7272.
This fix is validated (from Pioneer) on the VSX-26TX,VSX-27TX,& VSX-29TX it might also work in the VSX-908, VSX-908RDS and others as long as the same DSP board was used.
Let me caution and stress that surface mount soldering skills ARE REQUIRED to do this update! It also doesn't hurt to have excellent vision and/or an eye loop or microscope to check your work. Original ROM's were subject to timing changes internal to the part as a result of HEAT. This model does get HOT! The program was also modified as a further safeguard to re-occurrence.
1helpful
I have a RCA RT2250 and I have a green light on a circuit board
Check the solder connections on the seven voltage regulators found in the center of the receiver on the heat sink from front to back (not the amp board) they are on the main board. The green light on the DSP board (back right side) is an error light. You can reset the receiver by pushing power then stadium then night then dsp off then club after unplugging the receiver and plugging it back in.
Hope this helps,
JohnW
DSP Card (Onkyo TX DS787)
You should be able to get this directly from Onkyo. What is the problem tthat leads you to believe that the board needs to be replaced? Realize that the board could cost upwards of $100 or more.
Dan
6helpful
2answers
Technics sadx750 and says f70 and turn power off
7helpful
3answers
DENON AVR 2802 (NO SOUND)
If "Digital" sign blink on front panel, it means DSP do no start properly. If DSP do not start, main UC mute audio. Change IC, AT49LV002-70TC (IC 817 ) at DSP board (Denon P/N: 262 3010 006).
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
xxxxxx xxx
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
