Ever since the 1.10.16 firmware update, the video mover and usb print and storage center stopped working. Video Mover appears as unknown, In the settings it will not let me choose the check box to let compatible players used media attached to the router.
Use web interface 192.168.2.1
I noticed some changes as well. Go to Media Server (you should see attached USB drive there) > Twonky. Download and install. Verify Email. Check Spam folder.
Login Twonky > My Library > Look for you router ID and Beam.
I'm still not to familiar with the new setup, but Good Luck as well.
SOURCE: I can establish a link to the Net wirelessly and
Hi you need to be sure is the default settings of your router Belkin is USB ENABLE .
let me know is that still not working and ask me for a remote your PC
SOURCE: Setting up port forwarding: belkin wireless g plus mimo router
candice,
you can go to this links click here. Select the model of your belkin router and it will give you a guide on how to enalbe port for warding.
SOURCE: After update the firmware my belkin G stop working.
You may possibly be able to restore your router to factory default settings, by pressing the reset button on the back of the router.
You normally need to press for at least 10 seconds to get back to factory defaults (check your manual).
Sorry, there is no guarantee this will work, but it is worth a try. If it does, you will lose all customised settings (eg password, network key). :(
SOURCE: WD My Book 1TB not recognised by belkin modem router USB storage
Hi
i am fairly certain The WD my book external hard drive needs to have the correct software to be able to use and because routers dont have a CD drive i dont think you will be able to do it.
If I understand correctly ... You have not connected the drive to a computer.
If I am not mistaken the WD My Book has preinstalled backup software installed on it. It very well might also have a power down built as part of that programming. Try attaching it to a computer to verify this.
Assuming the backup software needs blank drive to work correctly I would first access the drive select all and delete anything you find (if you know how to unhide hidden files do that before you select and delete all) ... As a 2nd option I would just reformat the drive.
Hope that helps....
