Audiovox FPE1078 7.8 in. TV/DVD Combo Logo
Question about Audiovox FPE1078 7.8 in. TV/DVD Combo
Audiovox fpe2705 inverter board replacement
After some investigating, I've found that I need a power inverter board for my audiovox t.v. (FPE2705). I'm not sure which inverter board to order or the best place to order it from. Any advice is greatly appreciated... I'd also like to get some confirmation that this is the best solution for the problem with my t.v. having sound but no picture. Faint picture is visible when direct light is on the screen. I have the same problem with my Audiovox FPE1078.
Posted by nstotts on
  • dmrej Apr 28, 2009
    TV powers on but no picture - only barely visable with light
Steven Brandon
    Master:
  • Audiovox Master
  • 461 Answers
I usually order from www.shopjimmy.com for tv parts myself.
Darfon V0 88070 101 Backlight Inverter
Here is another site with a used one if you need it right now and cannot wait.
Audiovox Inverter Board 48v0708001 E2 For Model Fpe2705 24v Inverter...
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Posted on Jun 14, 2017
2 Related Answers
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: Audiovox fpe2705 inverter board replacement
You need to verify first that you do have 24vdc feeding the inverter boards, if you do have 24vdc then we can be sure it is the inverter boards. The inverter board will have very small surface mounted fuses, check for that also.
Posted on Dec 02, 2009
atang1
Arthur Tang
  • 734 Answers
SOURCE: I have an Audiovox FPE1078 and when I load a DVD
You play some music cd, then let the dvd cool down, you do it enough times the condensation will be gone and DVD can then be played. You use remote to keep it on standby, then condensation problem will be gone forever. I have the same model and fixed it this way.
Posted on Dec 10, 2010
Lcd tv model fpe2705 intermitently will not turn on. Need audiovox service center for out of warntee
HI,
Can you please give the zipcode of your area so that i can find a service center
27 lcd model #fpe2705 no picture only sound
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
[email protected]#
Hi my audiovox fpe2705 needs red color in shows only in green an blue thank you
remove back cover then check the CRT tube if there is color red cathode how?by using a wire or test prove connected in ground in your TV very quick if red screen flashes your CRT is good then check your CRT board socket find the driver transistor of red cathode then check it if shorted replace thank you
When I turn on the Audiovox FPE2705, it says the Audiovox logo, but then goes black. It looks like the back light just turns off. I think maybe the inverter or controller is turning the back light off. Is...
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Otherwise indepth troubleshootong required or you may end up replacing the wrong parts.
Please post back what you find.
3helpful
Audiovox FPE3206 - Power Light is Blue/ON but Screen is BLACK
I had the same problem, except with a flashlight I could see AUDIOVOX when i turned it on and I could see the video when I put a DVD in. It is hard to see even with a flashlight so you have to look closely. Well, I researched and investigated what might be the problem because I was upset that I had the TV for less than two years. Everyone was saying the inverter was defective. Apparently the inverter is what gives the LCD screen the back light to see the video. So I called audiovox and found that thier part's selection was only a power board and a remote control for this TV. I asked them if they could get me an inverter and they did. With shipping cost it was approximately $150.00. They ensured that I know that there is no refund on this part (which is common for electical parts). So I took a chance on it not being the right part for the problem. I replaced the defective inverter myself and it worked. It solved my problem. The inverter is a circuit board that plugs in and has a few screws to hold it in place. I had to remove the back cover first and a couple of brackets inside the tv to get to the inverter and replace it. There is a quite a few screws so I recommend writing down where each came from for easier reassembly. I hope this helps!
Flat panel tv
I had a similar problem, except I had sound and with a flashlight I could see audiovox when i turned it on and I could see the video when I put a DVD in. It is hard to see even with a flashlight so you have to look closely. Well, I researched and investigated what might be the problem because I was upset that I had the TV for less than two years. Everyone was saying the inverter was defective. Apparently the inverter is what gives the LCD screen the back light to see the video. So I called audiovox and found that thier part's selection was only a power board and a remote control for this TV. I asked them if they could get me an inverter and they did. With shipping cost it was approximately $150.00. They ensured that I know that there is no refund on this part (which is common for electical parts). So I took a chance on it not being the right part for the problem. I replaced the defective inverter myself and it worked. It solved my problem. The inverter is a circuit board that plugs in and has a few screws to hold it in place. I had to remove the back cover first and a couple of brackets inside the tv to get to the inverter and replace it. There is a quite a few screws so I recommend writing down where each came from for easier reassembly. I hope this helps!
2helpful
2answers
Audiovox FPE3206
I had the same problem on my Audiovox FPE 3206, except with a flashlight I could see AUDIOVOX when i turned it on and I could see the video when I put a DVD in. It is hard to see even with a flashlight so you have to look closely. Well, I researched and investigated what might be the problem because I was upset that I had the TV for less than two years. Everyone was saying the inverter was defective. Apparently the inverter is what gives the LCD screen the back light to see the video. So I called audiovox and found that thier part's selection was only a power board and a remote control for this TV. I asked them if they could get me an inverter and they did. With shipping cost it was approximately $150.00. They ensured that I know that there is no refund on this part (which is common for electical parts). So I took a chance on it not being the right part for the problem. I replaced the defective inverter myself and it worked. It solved my problem. The inverter is a circuit board that plugs in and has a few screws to hold it in place. I had to remove the back cover first and a couple of brackets inside the tv to get to the inverter and replace it. There is a quite a few screws so I recommend writing down where each came from for easier reassembly. I hope this helps!
No picture
Bad news if you see burned parts the board is a gonner. SMD and very difficult to repair. most time a replacement is the only repair. The board you are looking at is probably the inverter board. the inverter drives the back lights on the lcd display. Some of these boards can be costly. on some of these sets they use combo boards * ie signal and digital and power supply all on one board
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
