Question about Mag Innovision LT776s 17" LCD Monitor
Mag Innovision MS-776K 17 in. Flat Panel LCD Monitor
5 Related Answers
Anonymous
SOURCE: Mag Innovision LT776s 17 in. Flat Panel LCD
I have the same problem except it usually happens after Ive left my computer idle for a while... i.e . Overnight, I usually turn off the monitor and I hit the button after I come back to turn it on. I get the same flashing light for several minutes. This has been a problem for several months, but only recenly have i gotten the same error message you mentioned. Each time ive booted the computer up cold or restarted it has worked fine but this time it took longer along with displaying the message: Top Left to Right: SH770 P001 Bottom Left to Right: AU M170EN05 Anyone else who can clear this up?
Posted on Apr 12, 2007
Mergatroid
  • 286 Answers
SOURCE: MAG Innovision 19" TFT LCD Flat Panel Monitor
the monitor has bad backlights or circuitry. Call the company, their number should be in the owners manual. Or, look on the web for their website. Or, call the store where you bought it. The monitor must be taken to a service centre for repair.
Posted on Mar 27, 2008
Anonymous
  • 186 Answers
SOURCE: i need driver monitor mag innovision for install
Chek Ur OS and download drivers from here :
http://list.driverguide.com/list/company621/
Posted on May 16, 2009
SOURCE: My mag Innovision flat lcd monitor is blank after 3 seconds..
It is not easy. I slip a knife in the bottom edge and slowly work my way around the bottom opening it a little by little. Once you get the bottom and part of each side you can push the plastic towards the top and it will pop off. There are plastic clips holding the bezel down. I always break a couple on opening, but at least the monitor gets fixed. This is not made to open, so good luck.
Posted on Sep 22, 2009
Where to plug the power cord in the back of MAG TL765s Monitor
There should be another hole next to the speaker connections that says DC in, it goes in that hole.
Oct 29, 2009 | Mag Innovision InnoVision LT765 17" Flat...
I have a MAG INNOVISION LT765s LCD monitor. When the computer boots up, the power button on the monitor won't stay on so the display won't come on. It sometimes takes an hour of fooling around with the...
I have had similar problems with my Mag LCD monitor. I recently dicovered that the problem was with the adapter and not the monitor. Try replacing the power adapter.
Sep 21, 2009 | Mag Innovision InnoVision LT765 17" Flat...
THE MALE 15 P PLUG ON MY MAG LCD WAS CUT OFF.
here you go
http://pinouts.ru/Video/VGA15_pinout.shtml
Aug 07, 2009 | Mag Innovision InnoVision LT 765S 17" Flat...
MAG monitor is all white
please change your ram immeditately or monitor itself because the life of monitor has been came to an end...
Dec 31, 2007 | Mag Innovision InnoVision LT765 17" Flat...
Monitor problem
my monitor is 17'' lcd...... mag innovision model: LT716s..before was working well but now the lcd monitor don't to turn or either the led doesn't turn or make any sign.... no matter whta the lcd stay blak,,,,,do not want to turn on....
Dec 31, 2007 | Mag Innovision LT976S 19" Flat Panel LCD...
Waking up monitor
probably ur compuet may be in standby so u have to beat the keyboard to wake it up .
Dec 05, 2007 | Mag Innovision InnoVision LT 765S 17" Flat...
Mag Innovision LT776s 17" LCD Monitor Logo
Top Mag Innovision Computers & Internet Experts
Joe Goldman
Joe Goldman
ADMIN Canada
ADMIN Canada
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
