Post were corroded so we had battery checked, fully charged, cleaned terminals and reinstalled. horn was blowing but quit after turning key to start. at least that was what i was doing when horn stopped. can tell battery is plenty strong.
There should be an override switch - either you push it or toggle it - on the left side under the dashboard (next to your left leg) on the wall -- it is very small and kind of hidden. Put your key in the ignition and turn all the way up to cranking but do not crank. While it is there, push/toggle the override switch and while it is pushed, start the car. it will start
Read more: http://wiki.answers.com/Q/What_if_your_1998_Toyota_4_runner_anti_theft_alarm_is_on_and_your_car_wont_start_with_key_any_way_to_reset_the_alarm#ixzz27nzDd7kl
SOURCE: Car wouldnt start. Just a
check the main wire from the battery to the starter 1st if it is ok remove the starter and take it to any major parts store and them retest it on a bench machine (they do it free)
SOURCE: changed battery real cranky no start
check the fuses and circuit breakers near battery i'll bet one of them popped.
SOURCE: Horn/lights on 2002 Toyota Tacoma
Rewire your horn from the steering wheel to the horn. Its not difficult, I can't tell you how to take the steering wheel apart but you can get a Haynes Repair Manual. It'll have all you need and more. You can use speaker wire, split it in two. Run one cable from the positive in the battery to the horn switch in the steering wheel. Another from the switch to the horn. You have a short somewhere, to me is easier just to run new wires than to find the short-circuit. Make sure when you run the cables through the firewall you run through a grommet so it does not get damaged by metal. Before anything check your headlight wires that they are not touching the horn.
SOURCE: 2000 Toyota Tundra starts occassionally. Sometimes
Welcome to FixYa!
You need to replace the starter solenoid contacts, or the starter itself.
Note that the starter is UNDER the intake manifold. This is a VERY difficult job, and is not recommended to those who do not have sufficient automotive experience.
If you DO remove the intake, you MUST replace the intake manifold gaskets, or your engine will not run properly, due to air leaks at the intake mating surfaces.
