TV turns on momemtarily and then turns itself off. Green screen with horizontal lines is displayed briefly. What gives?
SOURCE: RCA Model # 20F510TD TV/DVD
What makes you think the picture tube is bad? What exactly are the symptoms you see? The RCA 20 inch picture tube is a good quality long lasting tube and I doubt I have ever seen a bad one.
SOURCE: Screen shows people with green shadows blurring
This is a common problem on this model. Call in a shop or do it yourself with parts and instructions from www.TvRepairKits.com
SOURCE: Rca model 20f510td. parental lock
Hello
You must have its original remote control to unlock the parential lock. If you haven't it with you now, try to buy it or gather it from any of your friends or relatives who owns the same model; just to unlock it. After unlock, you can use universal remote or so.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
