Question about HP Pavilion G4-1213nr 14" Inch 2.5gA4-3300m 4gb Ddr3 500gb Notebook Pc Black
HP Pavilion G series Laptop Speakers are making weird noises,please help.
Right speaker has stopped working and left speaker makes robotic elongated noises during music/sound in general
Posted by Noray Lee Lesa... on
NANDINI DUTTA MOU
    Master:
  • 551 Answers
You stop the speakers and add vlc media player it works nicely.
Posted on Mar 26, 2013
No sound on hp pavilion laptop
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
1helpful
Speaker's blown out.
You could go out and purchase a set of Active Speakers and plug them into your laptop that should sort out your problem.
The reason why the sound is "low" on the side is either that the coil in the speaker has died or that you have blowen the power amp and so all you are getting is the feed from what would be the pre Amp. So adding a set of Active speakers with their own amp should work
I just upgraded from a hp pavilion to a dell computer with windows xp.I have polk speakers but they do not work. Don't know their model no. They worked fine on the H.P. HELP!
Hi , make sure you have correctly , installed the drivers for the sound card or Motherboard you are connecting into your laptop...and make sure it is compatible with XP
Happy new year
Hope you come right bud :D
I'vs had my HP Pavilion Dv9000 laptop about 2 months now, and it has been great. recently however sounds have only been coming from the right sound channel. The left side just makes a starng buzzing noise...
There is a problem is the sound card. The HP laptop should be still under warranty, take it to the supplier to get it repaired under warranty. If you try to fix it yourself you most likely will void your warranty.
BOSE speakers won't work with my HP Pavilion Desktop......help!
try reinstalling the software for them then make sure your sound card drivers are installed properly
18helpful
Loud noise from speakers when laptop closed/standby
Hi there.
Your microphone is on, and when you close the lid it is closer to the speaker. It needs
a loud noise (like closing the lid faster) and it enters into a feedback loop.
We need to find a way to make the microphone not play back.
Try left clicking on the speaker icon in the bottom right of the screen, and click playback
options. Here mute the microphone, and see if it solves your problem.
Good luck
1helpful
2answers
Speakrs don't work on new HP Pavilion desktop.
If you're using Windows XP, go to the Control Panel, then double-click on Sound, then go to the Audio tab and make sure the playback device is set to your Realtek output.
If you're using Windows Vista, go to Control Panel and click on Hardware and Sound, then click on Sound. Make sure your Realtek device is selected with a green check mark. If it isn't, just click on it and then click the Set as Default button down below. Vista sound configuration is kinda quirky, and it does do some kind of detection when you plug a cable into an audio jack, so you might leave this screen up while you plug your speakers into the green audio jack in the sound card and see if it pops anything weird up.
My laptop speakers stopped working
check and make sure all the screws are tight. when mine quit working it was because a srew was loose from vibration.
2answers
Speakers make crackle noise.
tried to reinstall/update your audio drivers and tixed your sound equlizer.
1helpful
HP laptop speakers went out, fairly new
Hi kimberly,
If your laptop is still under warranty then this is something they have to repair for you. It sounds like a hardware error, not sure about the actual fault but two speakers burnt is weird. (Especially if you keep the volume near 60-70% of the max volume)
Still if the laptop is out of warranty then dissasemblying is required. The information required are all give to the Service manual of th DV6000 provided from HP itself along with the part list and coding of the new set of speakers you need.
The process is not hard actually for this model. It can be done fairly easy. (in other laptop a complete disassembly is required which is very tough task)
The manual you will need is the one below. (Simply left click)
http://h10032.www1.hp.com/ctg/Manual/c01035677.pdf
At page 146 you will see how the speakers are removed. Also follow the instruction on the quoted previous sections.
The part number of the speakers is 431447-001 and it is mentioned at the same page.
The part costs around 5$ used from Ebay :) If you dont believe me check it out yourself :)
http://cgi.ebay.com/HP-DV6000-SERIES-SPEAKERS-431447-001_W0QQitemZ180230305257QQihZ008QQcategoryZ16145QQcmdZViewItemQQ_trksidZp1713.m153.l1262
Many regards and I hope you can get your precious laptop working again as a charm :)
EngineerGR
HP Pavilion G4-1213nr 14" Inch 2.5gA4-3300m 4gb Ddr3 500gb Notebook Pc Black Logo
Top HP Computers & Internet Experts
Ekse
Michael Thomas
Michael Thomas
Mandeep  Singh
Mandeep Singh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
