Boston Acoustics PV1000 Subwoofer Logo
Posted on Sep 27, 2012
Hi I have boston pv1000 no power - Boston Acoustics PV1000 Subwoofer
1 Related Answer
Anonymous
  • 7 Answers
  • Posted on Dec 28, 2010
SOURCE: I have a Boston Acoustics
I have the same problem. La Mars covers the factory repair for these. Their number is 712-546-1644. Have you fixed your problem yet ?
Mark
Hi there hope someone can advise me! Bought a used boston soundbar tvee 20 and discovered the subwoofer stays on for a short while then goes off displaying a solid red light! I have tried everything thing...
I have sub woofer that works the same way. It is always on "idle" but when it detects an input it switches over to fully powered status and green light goes on. When I turn off receiver or whatever, it takes a tad for the unit to power down and go back into "idle" mode with a red light. .
3helpful
2answers
Boston acoustics pv-1000 won't power on
Just fixed my PV1000 that would not power on. Verified 185vdc on bulk capacitors. Measured 11vdc on U5 (UC3842) from pin 5 (gnd) to pin 7 (vcc). Then measured 0vdc from pin 5 (gnd) to pin 8 (ref). This should be 5vdc. This means that U5 is shut down for undervoltage. Turned out to be two open resistors. R94 100k 2w and R77 33k 2w. Never would have guessed that as there was no sign of heat discoloration. They are next to each other between U5 the UC3842 PWM IC and Q3. This prevented the proper startup voltage for U5. Replaced them and I'm off and running once again. Hope this helps someone.
My PV1000 does power up when plugged in. Can you send the wiring schematic and troubleshooting guide.
Hi David,
First of all, thank you for posting your question here at Fixya.
May you please email me at [email protected], I will send you the copy.
Again, thank you so much!
Rating and feedback are highly appreciated.
Mjsazon
I have a Boston Acoustics PV1000 that's getting no power but the fuse appears to be OK. What else could it be? thanks
Mark
1helpful
2answers
I get a low hum from my speakers. How can I get rid of this?
Boston Acoustics Media Theater HUM. The problem may be the power source. Find another DC power source for the 12 volt. All I had was a 14.5 volt 4.5 amps source Model PS6 power source which fit the plugin socket. Absolutely no hum now and still great sound. However, I would recommend a DC 12 volt source with at least 3 amps output.
2helpful
The amplifier module in my Boston Acoustic PV1000 Subwoofer has fried itself. According to the New Zealand importer, a new module is not available. Any ideas? Would there be a wiring diagram avail? Maybe I...
Here is information from the factory repair company for this product.
For repairs that are out of warranty: The Boston Acoustics PV1000 has a $130 flat fee that covers parts and labor regardless of the problems you are having with the unit. Return shipping is figured (with your zip code) at the time of return and added to that fee.
When packaging the unit please include a detailed problem description and
full contact information (name, address, phone). For this particular model you can send in just the amplifier pcb, and keep the cabinet in your possession, (to save immensely on shipping)
Upon arrival here at LAS, your name first and last will become the RA and
future communication will be referenced by that name.
We will contact you for payment of $130 +return shipping. We accept Visa and Mastercard over the phone, or check or money order via mail. Turn around time is generally 3-5 days
after receipt of the unit.
If you have any questions or uncertainties don't hesitate to call the number below or respond to this email.
The address for return is:
LeMars Audio Service
1889 24th St SW
LeMars, IA 51031
712-546-1644 opt2
Need new Power Supply Boston Acoustics Model No.
Boston Acoustics 12VAC 3000mA (3A) Adapter -BA Model DM12-3A0-1AN Only Source: BA Direct (in NJ: 978/538-5000) $54.00 (Incl. S&H) Ordered one on 7/8/09. Meow! Florida
No power to my subwoffer
Boston Acoustics Model DM12-3A0-1AN (Power Supply Adapter) 12VAC 3000mA (3A) Only Dealer is BA Direct in NJ Phone: 978/538-5000 Just received one on 7/14/09: $54.00 (Incl. S&H). Meow! Florida
3helpful
2answers
POWER SUPPLY
Hi, the mA rating for this power adapter is 1500 mA !! I'm gonna give you all the specs. you need to order a new one, and I'm gonna tell you where you can order a new one at; at your preference ?
POWER SUPPLY/POWER ADAPTER TRANSFORMER FOR:(WALL PLUG IN)
BOSTON ACOUSTICS MICROMEDIA SYSTEM 7000596
2.1 SURROUND (2 SATELLITES) (1 SUBWOOFER)
MODEL # WK1201A5-1 AN (THIS IS THE MODEL # FOR THE PLUG)
I/P(INPUT) 120 VAC 60 HZ / 23 VA
O/P(OUTPUT) 12 VAC 1500 Ma
This is all the info you need to order a brand new one in the box.
Go to www.emtcompany.com and in your search box punch in the model # wk1201a5-1an. they cost 29.99 new but its worth it for a great sound system. good luck and I hope I helped a bit
steve - if you have any further questions, i will be glad to help out, you can email me [email protected]
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
john h
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
