When i plug in my charger to the laptop the light wont come on and the laptop wont charge.
SOURCE: broken nc10 charger
Depending on what type of plug it is you may be able to change the fuse.
If the fuse has blown then you really need to know why before plugging it back in to the mains. The charger may have a broken wire in the lead that plugs in to the laptop. Usually it happens right near the plug where it gets bent and twisted. It could also be the internal fuse inside the charger box.
If you can't get it tested properly then a new one is your best bet. They are quite cheap on Ebay. Just look for the one for your make and model number and check to make sure the voltage on your chargers label is the same, it's output voltage is probably 19 volts. The voltage must be the same, NOT lower or higher.
Then have a look at the label for the current which is in Amps, something like 3.15Amps. You can buy one with higher current than the one you have but NOT lower than the label says.
