I also need front wheel for green little tikes tractor and yellow plastic screws for older toys.
SOURCE: Broken Plastic underneath car towards front
Bueno, se puede reparar con adhesivo especial. Ademas se puede reforzar con laminas de aluminio que dan rigidez a pieza.
THIS PART IS EITHER AN OIL COOLER OR POWER STEERING FLUID COOLER. IF THE COOLER IS LEAKING, IT CAN BE BYPASSED BY PUTTING THE TWO HOSES TOGETHER WITH A FITTING AND TWO HOSE CLAMPS. GOOD LUCK, THANKS FOR AN HONEST RATING AND FOR USING FIX-YA
SOURCE: I have a 1999 Chevy Lumina car. I had to replace
It is a vacuum holding cell which is needed to feed vacuum to the heater air condioning controls inside your car. Also other vacuum related items feed off this vacuum tank
Testimonial: "Thank you very much. You explained this very well. Thank you again!"
