Question about Dometic Rooftop RV Air Conditioner
Need a replacement r v air conditioner shroud polaris by dometic 28inches wide 41 7/8 inches long & 9 1/2 inches high
Posted by p.martignetti on
Mike Butler
  • Dometic Master
  • 6,674 Answers
Can you get model number of bottom of upper unit, from inside the trailer? The roof unit model number will make it easier to find replacement shroud.
Posted on Jan 28, 2013
5 Related Answers
Anonymous
SOURCE: Dometic Rooftop RV Air conditioner
why is our dometic roof top a/c on our boat draining water back into boat. is there a way to clean the drain?
Posted on May 30, 2008
Anonymous
  • 68 Answers
SOURCE: need to know how many amps the model # 57915.741 draws
Compressor amp draw is 7-8 amps
Posted on Mar 19, 2009
Anonymous
  • 68 Answers
SOURCE: Error code of E4 on Dometic HP air conditioner ??
16. SYSTEM RESET
a. Turn the ON/OFF switch to “OFF” position.
b. Simultaneously depress and hold the MODE and ZONE
push-buttons while turning the ON/OFF switch to “ON”.
FF should appear in the LCD display until the MODE
and ZONE push-buttons are released.
c. When a dip switch is turned on or off after initial configu
ration, a system reset will need to be done before the
Comfort Control CenterTM will recognize the updated selection. Try this. This is for the five button thermostat. Did you check the dip switches to be sure the proper ones are turned on? I need to know which stat you have 4 or 5 button. I have trouble shooting for both.
If you notice reset needs to take place after a dip switch is turned on or off. The dip switches are on the circuit board. You need to drop the lower cover. the dip switches will read in this order #1 heat strip/ #2 zone2/#3zone3/ #4 zone4/#5 furnace/#6 differential/#7stag/#8 gen start. Check this out and be careful. Turn off the stat to change dip switches. On will be toward the description. If you don't have remote start gen set the dip should not be on. If you dont have a Zone 3 the dip should not be on, etc.
Any questions feel free to post back
Thank you for using fixya
Jerry
Posted on Mar 26, 2009
Anonymous
SOURCE: Older Penguin roof shroud, new style fit?
I just replaced my two 620315.321 shrouds with the newer style without any problems. I went to the Camping World site (and called them) with model no. and they knew what to send me. I also found that they had the best price at $79.00 (member price) with free shipping.
I didnt check your shroud part no.s, but think you will be ok if you do as I did.
If you have any question about installing, you can email me at [email protected]
Posted on May 05, 2009
falspet
Fal Mueller
  • 438 Answers
SOURCE: two air conditioners & two furnaces with one thermostat
use relays to combine the to and isolate from each other or observing polarity's, you should be able to parallel the connections from your thermostat
Posted on Jan 28, 2010
Where do i find the model # on rooftop dometic ac? i lost the cover and need to order a new one?
Regarding location of the model number, look under the ceiling bezel on the inside of the RV. Also, many aftermarket replacement shrouds will fit several different models of Domentic air conditioners. You might want to check out pplmotorhomes.com
Jan 23, 2015 | Dometic Rooftop RV Air Conditioner
Trying to install dometic shroud 3309518.003
install low end of shroud down over band then pivot high end down over band. if still a problem take a strap and tighten around band to hold in.
Dec 08, 2012 | Dometic 3309518.003 Brisk Air Conditioner...
Where can I find a shroud for my 2003 model 59516.331 duo-therm high efficiency Dometic roof mounted dometic RV air conditioner?
Try googeling Camping world ,Adventurerv ,or best rv and truck supplies ,these are all in the USA who deliver to Australia.I usually find that it is much cheaper to buy parts like this from the US even with the delivery charge.
Good Luck John
Oct 11, 2012 | Dometic Rooftop RV Air Conditioner
I need to replace a broken shroud on a Duo-Therm Brisk Air Model # 59715.531 Where can I purchase a matching shroud?
americanrvcompany.com Once on the site go to air conditioners on left hand side then Dometic A/C. They should have what your looking for.
Jul 05, 2011 | Dometic 57915531 Air Conditioner
Where do I find the model number of my Dometic air conditioner that is on my RV?
Remove the shroud. You'll find the model and product number on the side after removing the plastic shroud.
Oct 04, 2010 | Dometic Rooftop RV Air Conditioner
May 05, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
161 people viewed this question
Top Dometic Heating & Cooling Experts
Marvin
Marvin
Sheldon Dedek
Mike
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
