Question about Polaroid FLM-2011 Television
Sky remote code for a polaroid p24led12 tv - Polaroid FLM-2011 Television
  • star_02uk
    star_02uk Feb 07, 2013
    0584 worked for me
4 Related Answers
Anonymous
  • 1099 Answers
SOURCE: need a code for sky hd remote for polaroid tv
hello,
Well first you can try - 065, 244, 405, 318, 037, 398, 191, 459, 245, 389, 060, 275, 0206, 0584, 0742, 0851, 1165, 1176, 1208, 1219, 1280, 1293, 1665
if none of the code works for you then please follow the below link to know how to search your sky remote code -
sky.com/portal/site/skycom/skyhelpcentre
also check the below link -
skyuser.co.uk/tools/remotecodes/index.php
Good Luck!!
Posted on Jun 01, 2010
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: code problem
I got a tip for this and in this tip are codes you can TRY, now the sky universal remotes are senstive to tv codes so you need to try the manufacture codes if that does not work then you need to ditch the sky remote and get a remote that works with the sky box and the tv as a solution. IN my tip there are remote solutions as well, please do not shoot the messenger I am not sky or the manufacture I am just helping for free,
http://www.fixya.com/support/r4873816-universal_remotes_remote_codes
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 12, 2010
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: WHATS THE CODE FOR POLAROID TV, MODEL TLU-01941C
We have answered you orginal question, This will be the secound time I done this for you. I am not upset its probably the system repeating issues, Read my tips on this
there are two links with a buch of codes hope this works out for you. please do leave your feedback and ratings on this, thanks
BElectric
DILLIGAF
  • 1140 Answers
SOURCE: polaroid lcd tv model no tlu03711c need codes for
Your code should be 1239 but if this doesn't work, please post back and I will try to find alternatives.
I can also provide instructions for programming the remote if required.
Please rate this solution if you find it helpful. Thanks.
Posted on Oct 16, 2010
Hi I have a poloroid 32" LED tv MSDV3233-U3 Need a code to operate sky q remote ECO60
polaroid is the badge not the manufacturer, Its probably manufactured by Starlight, sky dont list any codes for them, but they do list 3 under starlite.. which may be the same company .065,037,292 all worth a try I suppose. http://sky.xorro.co.uk/sky-remote-codes.html#biglist
Oct 18, 2017 | Televison & Video
HOW TO FIX A POLAROID P24LED12 TV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window".
Jul 23, 2015 | Polaroid Televison & Video
Hi can you help me please , ive bought a polaroid lcd tv model no p40lcd12 . ive looked everywhere on the net for the remote code for my sky + remote. sky dont have it listed .has anyone got it .would...
I bought the same TV yesterday and I've used code 1065 to program my sky remote, which worked fine. It's thanks to the answer relating to Mitsubishi and TiVo cos I used a Mitsubishi code!! Hope it works for you.
Sep 23, 2012 | Televison & Video
Need code for polaroid tv for sky
I've posted a clarification request above. You need both the TV model number and the version number of the Sky remote to find the correct code. I install satellite systems - I have access to the entire code database for all versions of Sky remote.
Oct 19, 2011 | Televison & Video
Code problem
Jun 12, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
Need a code for sky hd remote for polaroid tv
hello,
Good Luck!!
Jun 01, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Polaroid tlu01911cu remote code
I have one like this and found out its code is 0486 as a TV on a Silvercrest programmable remote
Jan 04, 2009 | Polaroid 1720-7 Remote Control
Sky remote do not work wit polaroid tv 3232
I own a One-for-All universal remote (model URC-4220), and my booklet says the setup code for a Polaroid TV is 0765.
Hope this suggestion, helps you out. Please take a moment to rate this info, by using the rating system below. Thanks.
Jul 12, 2008 | Polaroid FLM-3232 Television
Polaroid FLM-2011 Television Logo
Top Polaroid Televison & Video Experts
Paul Bade
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
