Question about Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel kelvinator II smart drive 501 washing machine stops washing mid wash
Posted by alice_boshel on
Greg Stephen
  • Fisher and P... Expert
  • 566 Answers
Check the out of balance switch under the blue motor controller
for corrosion replace if corroded.
Posted on Dec 19, 2013
5 Related Answers
Anonymous
SOURCE: Smart drive 5.5 washing machine lights show power on but no go
OK Problem located (without Diagnostics) , the problem was a faulty START/PAUSE button. I took the display board apart and fiddled with the button (whilst the power was UNPLUGGED) Starts almost every time, when it does`nt fiddle some more.
Posted on Dec 16, 2008
Anonymous
  • 4 Answers
SOURCE: Have a fisher & Paykel
Go to similar problem posted by ronnelini on Sept 8 2008, and see my suggested solution.
If you're lucky it could be a quick and cheap fuse replacement.
Good luck.
DIY Eddie.
Posted on Sep 16, 2008
Anonymous
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
luisa_sgro
  • 713 Answers
SOURCE: it dose not go to spin
Hi just read your posting.Now just a couple of questions.Does your machine drain the water If it does not drain the water remove most of the water by hand so you can tip the machine back so you can look underneath .Now you will see a pump to the front right of the machine.It will have a red or black fan attached to it.Turn the fan a few times to loosen the pump if it is tight .If it loosens when you turn the fan put it back on its feet and select a spin cycle and push the start button.Hopefully it starts to drain.If it drains it should spin. Please reply with additional information or if it starts to drain.Good luck.
Posted on Jun 15, 2010
Anonymous
  • 10 Answers
SOURCE: fault 49 smartdrive
Hi have had this problem on phase 5 grey controller, on the controll board near where the valve hot and cold wires are connected you will see a small usually blue resistor value approx 5ohms this is probably open circuit replace it check your water valves before reconnecting I was fortunate enough to have plenty of spare valves so I just replaced both valves as I suspect a faulty one may have damaged resistor machine has been working fine for some time since
Posted on Jul 11, 2010
Kelvinator smart drive 085 washing
Your lid magnetic reed switch could be faulty.
Fisher and Paykel Kelvinator Pride 5.5 Smart Drive 9 won't spin
There's something wrong with it. It sounds like its broken and needs to be fixed.
Kelvinator smart drive 035
there will be a series of lights lit up aswell, these are a fault code and will give some more information.
Leaking fisher & paykel smart drive 501
Check your hot and cold hoses at the back for leaks,
these are just crimped on plastic ends and can crack and leak..
1helpful
You need to read the error code
and tell me what lights are on
1helpful
My Fisher and Paykel Smart Drive 501 toploading machine won't finish its cycle...it always gets stuck on the spin cycle and starts beeping. This happens every time not just occasionally. How can i fix...
need to have a look at the machine, how old is the machine 15 years roughly, Yes this is when the machine plays up, hard to find spare parts. If you are getting rid of the machine let me know. 0412676652 Since I want to learn fixing the machine, I did fix one of this model long time ago
Fisher & paykel 501 smart drive washing machine
It does not seem like a problem of the unit. It might be a loose connection of supply code. Keep the supply code pressed to the unit in different directions and see if the unit takes power. If so, replace the supply code. It's not that expensive.
1helpful
Fisher and paykel washing machine stopped mid-cycle and beeps constantly. 2nd button in is solid green.... 5.5kg smart drive model.
If the light that stays on when beeping is 7th from the right then the machine has a pressure transducer which is out of range, the motor controller module (electronic) will need to be replaced.
2answers
F & P Kelvinator Smart Drive 708 - Faulty power switch and cycles
I have a smart drive 708 that will turn on but won't fill, any suggestions?
Fisher and Paykel GWL11 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
