Cameras Logo
Posted on Sep 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHAT IS DC 3.15V - Canon Cameras
ernesto cuadra
Level 3:
Top Expert:
  • Canon Master 12,223 Answers
  • Posted on Sep 27, 2012
ernesto cuadra
Canon Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4080967
Points
34431
Is the voltage of continuos voltage for batteries, example any batteries such : AA +AAA+D+C has 1.5 Vdc or 1.5 voltage continuos. Not alternating. Alternating is only coming from outlet wall.
Model 841.205 lw2019. Where can I buy 13 vdc motor?
13v Dc Motor - Alibaba.com
www.alibaba.com > Mechanical Parts & Fabrication Services > motor
13v Dc Motor, Buy Various High Quality 13v Dc Motor Products from Global 13v Dc Motor Suppliers and 13v Dc Motor Manufacturers at Alibaba.com.
12V DC Motor ' eBay
www.ebay.com/bhp/12v-dc-motor
eBayFind great deals on eBay for 12V DC Motor in Electric Motors with Less Than 0.5 HP. Shop with ... Buy It Now. 209 watching ... Igarashi 12 VDC Motor - 4500 RPM - 12 V - Toy Car and Hobby Motor - High Torque. $6.95. Buy It Now ... Worm Motor. Output Shaft Size 1.5 x 13mm/0.06 x 0.51 (D*L) Shaft Total Length 47mm/1.7.
Ametek Motor ' eBay
www.ebay.com/bhp/ametek-motor
eBayAMETEK MOTOR GENERATOR E56617 72 V DC WINDMILL TURBINE PERMANENT MAGNET WIND. $145.00; Buy It Now ... Ametek/Lamb 116765-13 Vacuum & CentralMotor, NEW 110 volt 3 stage. $114.79. Buy It Now. Free Shipping.
tip
ERROR codesCanon 7050
Canon 7050 E000 Heater (Reset by unplugging machine) E001 Heater triac, DC controller, AC driver (reset by unplugging) E005 Fuser cleaner belt at end. Replace. E010 Main motor, DC controller or DC driver board E011 Any motor ( main, scan, cleaner belt, duplex, toner, lens) DC driver, DC controller, duplex driver board. E020 Toner out signal has been sent for at least 3 minutes E050 Duplex E203 Scan motor, DC driver, DC controller E210 Lens home sensor not actuated or won't deactuate E240 Controller board E241 Controller board E242 Controller board E400 DC controller, Doc. Feeder board, 24V power supply E500 DC controller, sorter board, 24V power supply
How the SMPS is working in telecom? What are the functions of SMPS? How it is Converting AC to DC? What are the parts are there inside the SMPS and their function?
smps involves ac to dc and dc-dc switching at high frequency because the type of a transformer in smps is a high frequency transformer and a current gain due to the ferrite application.to do a dc to dc switching you need a mosfet,smps ic e.g uc3845,dc capacitor and some passive components.
Transformer AC 9 Volt, battery 4x 1.5 Volt DC. On
first is no i would not recommend feeding the 9 volt dc through the actual 9 volt ac it may damage the bridge rectifier that converts the ac to dc
3answers
Hi when plug in my ac adapter into lenovo x61 the tablet will not turn on i try it on other computer and it will on what happen?
LOL, sounds like your tablet has seen it's better days. See why HP got out of the Tablet business? They are nothing but trouble.
2helpful
4answers
Hello my laptop t41 power is not even flash but the adapter is working,am technician and i have troubleshoot allot.
I concur with what Diegotech stated.
To iterate further;
1) The DC Power Jack (DC IN), may have cracked solder joint/s on the motherboard connector, (Female), where the DC Power Jack plugs in.
Resolder
2) The DC Power Jack may be broken.
Center Pin mount, and/or body of DC Power Jack, and/or Outer Shell mount.
Replace DC Power Jack.
3) Wires from the DC Power jack plug to the female connector on the motherboard, may be bad.
Two examples, of a place to buy an IBM ThinkPad T41 DC Power Jack,
1) http://www.buy.com/prod/dc-power-jack-connector-socket-for-ibm-thinkpad-t40-t41-t42-r50-r51-r52/q/sellerid/23962916/loc/101/215782035.html
2) http://www.machinaelectronics.com/store/buypart/IBM_Thinkpad_T41/DC-P001
Past this point it's a bad DC sensor on the motherboard.
Replace motherboard.
IBM ThinkPad T41 Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-ibmlenovo
On this page go down to the 8th line.
The one that starts with > ThinkPad T20.
Go across, and click on > T41
Takes approximately 2 seconds to see the first page, and additional time to fully download.
Page 142 for 14.1 inch LCD screen
Page 151 for 15 inch LCD screen
(PDF file page number box at top)
I HAVE LOOKED EVERYWHERE FOR A BATTERY FOR MY ADVENT DIGITAL CAMERA (ADV 1182E) BUT NO LUCK. CAN ANYONE TELL ME IF ANOTHER BATTERY CAN BE USED??.
Three years ago a guest on FixYa wrote this:
quote
Here's a list of cameras that use the same battery.
ADVENT:
ADV1172E
BENQ: BENQ:
DC C500, DC E43, DC E53, DC E63+, DC E720 DC C500, DC E43, E53 DC, DC E63 +, DC E720
KONICA MINOLTA: KONICA MINOLTA:
DiMAGE E40, DiMAGE E50 DiMAGE E40, E50 DiMAGE
PREMIER: PREMIER:
DS-4331, DS-4346, DS-5330, DS-5341, DS-6330, SL-6, SL-63 DS-4331, the DS-4346, the DS-5330, the DS-5341, the DS-6330, SL-6, SL-63
ROLLEI: ROLLEI:
Prego DP4200, Prego DP5200, Prego DP6200 Prego DP4200, Prego DP5200, Prego DP6200
End quote
Nov 27, 2010 • Cameras
2helpful
I want to know the meaning of code 6010,6013 and 7018.
The first two numbers are the streangth. (60=60,000lbs) the 3rd is the posititon 1 : Flat, Horizontal, Vertical, Overhead.2 : Flat and Horizontal only.3 : Flat, Horizontal, Vertical Down, Overhead. The fourth digit is the current and coating 1 : DC:ROD+ ................... cellulose sodium
2 : AC or DC:ROD+ or DC:ROD- .. cellulose potassium
3 : AC or DC:ROD- ............. titania sodium
4 : AC or DC:ROD- or DC:ROD+ .. iron powder titania
5 : DC:ROD+ ................... low hydrogen sodium
6 : AC or DC:ROD+ ............. low hydrogen potassium
7 : AC or DC:ROD+ or DC:ROD- .. iron powder iron oxide
8 : AC or DC:ROD+ ............. iron powder low hydrogen See this attached link:http://www.jeep-l.net/info_jeep/weld_rod.htm
6helpful
3answers
Intermittent dc jack connection for Gateway mx3215
Here is how to disassemble Gateway laptop,
Here is replacement DC socket (needs soldering),
Here is DC board (no need soldering, but expensive).
Hope this helps.
3answers
Advent camera battery charger
ADVENT:
ADV1172E
BENQ: BENQ:
PREMIER: PREMIER:
ROLLEI: ROLLEI:
Hopefully this will broaden your options when searching for a compatable charger.
Mar 23, 2008 • Cameras
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
