My files for the GSM went missing and as a result the phone part of the phone is not working. I tried downloading the GSM from HP website but it give an error of failure to communicate with the device. How can i solve this problem and restore those file and have the phone part work again.
Its a RETIRED product
ok so make HP day as them for files , now deleted.
get it repaired, at 100x its value?
why, mess with any IPAQ. ever.?
it has zero street value now. why? why not get used smart phone for $10 and work that?
https://h30434.www3.hp.com/
SOURCE: Ipaq Quick GPS connection file downloads
You may need to use the hard reset to make the quick gps connection working. but you will lost all ur program or data, including smart nav or tom tom. if you ready want to use the hard reset, remember to download smart nav or tomtom program. or you will end out no map in your system. good luck
SOURCE: Detect camera in Hp Ipaq hw6515 PPC
I have been working on Camera cell phones and see these kinds of issues. I am afraid that your camera interface was bad and the phone main board is not recognize the connected camera. I don;t think this is a software isue when it error message said connect the camera or reset pc.. If you are not think my suggestion is correct, you may try the other way by flashing the ROM as updating the new ROM version, it may also hlep to solve this issue and if it is still not, then I am sure th efaulty is from your camera. This is an comment issue in most camera phones I have been fixed before. I hope it help.
SOURCE: iPAQ file store problem
You're not alone! Virtually every ipaq rx3715 gets this problem at one time or another. Unfortunately, it is a massive memory issue. Be prepared to potentially lose all of your data, including programs. My suggestion would be to back up your ipaq before you do this. I do not know if the backup retains the memory error, but what I would do is back it up, perform the fix, and then restore the data back onto the ipaq. If your file store problem is fixed, there you go! If the problem comes back upon restoring the pocket pc, then unfortunately you will lose all data and programs in order to fix the memory, and that will be a personal choice. For most of us, the ipaq simply freezes up upon entry into the file store, so consider yourself lucky that they simply do not delete.
Here is the step-by-step process of how to fix your problem.
1. Download GER and ENG ROMs (latest) from HP's support site
2. Unpack both
3. Cancel the automatic flash procedure.
4. Locate the EnterBootLoader.exe file in the folder of the unpacked GER update
5. Copy it to PPC
6. Run it from the PPC
7. Run the ROMUpdateUtility.exe file from the desktop to start flash procedure.
Then you have a German-language PPC
8. Locate the EnterBootLoader.exe file in the folder of the unpacked ENG update
9. Repeat steps 5-7 for the English update
You're done
Remember, you're not alone! We all had the same problem.
SOURCE: HOw and where can I get downloadable games for my ipaq?
I had the 3985 few years ago.
here are some websites
http://www.pocketgamer.org/games/
http://www.pocketgear.com/
Basicly you run the setup program on your pc and then it installs it on the pocket pc. I can actually do you a video if you wish, would you like that?
SOURCE: hp ipaq quick gps connection driver
I needed to get my data connection with my phone company right so to download any data, then I could get the files.
You don't have to have those files, they only speed up the sattelite location process.
