My installer tech checked the battery was installed properly and said to try to charge it overnight. I did but it still won't work unless it is connected to the cradle with ac power.
SOURCE: Harmony 785 charging cradle does not charge the remote
Try pressing down on the remote, and wiggling it around. It's just that the pins are not making contact I suspect.
If pressing down helps, you can fasten it on with a elasitc band or something so that it keeps charging. Also, if it is still under warranty, I woul advise contacting Logitech's wonderful support team to get replaced.
Hope that helps!
Testimonial: "Thanks - this solution helps."
SOURCE: won't charge in cradle, shows slide show then
The early 880's had problems with the charging circuit. For a while Harmony was replacing these units even outside the waranty period. Not sure if they are doing this anymore. However your remote is recognizing that it is in the craddle because the slide show starts which means the charging circuit in the remote is not passing power onto the battery or the battery is not making a good connection inside the remote. I would pull the battery and clean the little contacts in the remote and the contact pads on the battery. If you have a volt meter I would pull the battery and check voltage. You should see around 4 VDC on the 2 outside copper pads if it is charged. If it is charged and the remote is not working then its time for a new remote. If the battery is dead then it is likley the typical charging problem of the 880 is causing the failure. Hopefully cleaning the contacts both inside the remote and in the charging craddle will solve the problem. Use alcohol and a q-tip to clean all of the contacts.
Good Luck
SOURCE: Hi, my logitech harmony 700 says I need to
same with me. took batteries out and replaced, all fixed
SOURCE: logitech harmony 880 won't charge
Clean the leads on both the charger and on the remote itself with rubbing alcohol.
We had this problem (it would lose connection periodically for no apparent reason, then eventually wouldn't even register that it was set down). The leads sure looked clean, but shining them up with rubbing alcohol (recommended on one of the Logitech boards) got it to start charging again.
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
- Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
- Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
- Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.Figure : Charging with the universal desktop cradle
- AC adapter into electrical outlet
- AC adapter into universal desktop cradle
- HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
- Connect the HP iPAQ Pocket PC to an A/C power supply.
- Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
- Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
- Turn on the HP iPAQ Pocket PC.
