ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV Logo
amano Posted on Sep 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Searching a channel - ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Level 3:
Top Expert:
  • ESA Master 76,851 Answers
  • Posted on Sep 27, 2012
ESA Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15007494
Points
237762
It sounds that the main system control memory IC has gone faulty. Check and replace it.
Why am I stuck on one channel
There is only one channel in auto search. Just open searching menu and auto search again your new channels.
Wont find channels on auto channel search
Ensure that you have a good connection to your antenna/cable/satellite, and that you have selected the proper signal type in your TV menu.
If you are using a cable box or satellite, you might need to search for an analog signal on channel 3 or 4. If your cable/satellite box outputs an HDTV signal, then search the digital channels. If you are using an antenna, search for digital channels and set it the TV to Air in the Channel menu.
Need to scan channels
you can do the auto search channel. just press the tv menu and then find the channel search and select auto search. so that all available local channel will tuned.
I know this tv has digital capabilities, so i don't need to get the digital box, what do i need to watch my local channels? i have directv but does not include local channels (ie. fox, abc, nbc).
Hello
To tune the local channels do the following.
1 Press the MENU key on the remote control to
display the Main menu.
2 Use the CURSOR "UP" or "Down"
keys to highlight
Manual Channel Search. Press ENTER.
3 Use the CURSOR "Up" or "Down"
keys to select Cable,
Air (Antenna), or Digital Add-On.
After the search is complete, the HDTV will exit the
menu system and return to normal TV viewing.
IMPORTANT FACT: This HDTV maintains only one database
of digital channels. Therefore, when you search for
cable channels, the database of antenna digital channels
will be deleted. You will only be able to receive those
ClearQAM channels your cable company provides.
NOTE:"Not available" will appear on the screen
when an option is unavailable.
TUNING MODE UNAVAILABLE MENU OPTION(S)
Analog RF Digital Caption
Digital RF None (all Menu options available)
Video 1 Manual Channel Search, Channel Scan
Memory, Digital Caption
Video 2/3 and Manual Channel Search, Channel Scan
HDMI 1/2 Memory, Digital Caption, V-Guide
OK.
Programming channels
The only thing I see in the Manual is to do an auto search which will scan all available channels and saves them to memory. the faxtory setting is auto search. the search allows you to manually search for available channels. in this mode, available channel must be stored individually. the program sets your favorite channel to appear when the tv is turned on. the range is from channel 0 - 255. i hope this helps.
Auto search through
Tested and verified solution:
  1. Set Tuner Mode to "antenna".
  2. Run a channel scan. Should get zero channels found.
  3. Set Tuner Mode to "cable".
  4. Run another channel scan.
  5. Celebrate!
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Auto Channel Search
sounds like the tuner section of the main pcb isn't working properly.
5helpful
2answers
Digital tuner
Try this!
The manual states the TV is designed to search for channels.
turn the power on
then hit menu
(if it doesn't start searching for channels)
then hit channel up -let it run a complete channel search
hit menu again
hit channel up- let it run a second channel search
hit menu again after it finishes it's 2nd search cycle
if it doesn't go to a channel, hit the input button.
it worked for me!
hope it helps
Top ESA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you an ESA Televison and Video Expert? Answer questions, earn points and help others
