Question about GE Refrigerators
Side by side GE turbo-cool Gss25XSRBSS, the freezer seems to be fine, the fridge is not cooling. Fans seem to be running smoothly, no weird noises. Turbo cool turns on. It hasn't been running for
Posted by James Nunn on
redneck_h959
    New Friend:
I have a GE Refrigerator GSS25XSRBSS the thing wont get cold,the fresh food side is cool but not cold,and the freezer is not cold at all,i replace the evap fan and it does not run,I replaced the defrost therm and it does not run,I replaced the control board and it does not run,the damper is working because that fan works,and I can see the fridge light thru the damper hole in the freezer,i also replaced the defrost heater,what else can be wrong
Posted on Nov 15, 2012
  • 1 more comment
  • Sal De Nov 21, 2012
    there's a temp. sensor that's on the top of the evap coil part number WR55X10025,if this is bad the freezer will not get cold,look at the sensor,if it has a black ring around it where the wires connect to the sensor it's deffinetly bad and has to changed out, go here and you can see the sensorhttp://www.repairclinic.com/PartDetail/Thermistor/WR55X10025/914093
    http://www.repairclinic.com/PartDetail/T...
    also is the compressor running?you say the fridge is cool so it sounds like it is,if so check the sensor,when you change out the mother board in the back of machine you should change out the sensor to if it has a black ring on it.also you installed mother board part WR55X10942 ,this is the newest board for your machine.
Sal De
  • GE Master
  • 2,699 Answers
If you go here you can see the damper,fan assy. that's in the top of your machine in the fresh food side
http://www.repairclinic.com/PartDetail/Damper/WR49X10091/1055112
this is a damper with another fan in it,when the t-stat calls for cold air the damper door opens to let the cold air in from the freezer and the fan in it blows the cold air around inside the fridge,if the freezer is fine and the fridge side is warm most likely this is your problem,part number WR49X10091 and it's around 130 dollars.unplug the machine,remove the light cover on the ceiling,remove the 1/4 inch screws and drop the light assy.remove thhe filter cover on the right side so you can remove the damper assy.pop off the cover on the piece that runs up the back center,remove the screws to the damper,read the instructions and put it back together again.should take you around 45 to 60 minutes.hope this helps and good luck.
Posted on Sep 27, 2012
  • 2 more comments
  • James Nunn Sep 27, 2012
    thanks so much, I'll give it a try.
    and get back to you about if it works :)
  • Sal De Sep 27, 2012
    james,as long as you don't have a defrost problem and you can tell if this is happening by checking the back inside wall of the freezer to see if there's any frost on the wall,and also that one of the doors weren't left open and you'll see frozen water droplets on the packages most likely this is your problem,
  • Sal De Oct 05, 2012
    how did you make out with your fridge
5 Related Answers
Anonymous
  • 290 Answers
SOURCE: GE Profile CF24W-PL
Make sure the fan inside the freezer is running. If so, remove the cover from the back of inside of the freezer. If it is clogged with frost you have a defrost circuit problem. Most likely the defrost heater mounted at the bottom of the evaporator coil is burned out.
Post back with any questions and let me know what you find.
Thanks/Mike
Posted on Jan 09, 2008
Mike Inman
  • 219 Answers
SOURCE: Freezer Fan making humming noise until Turbo Cool is pushed - GE
yes need to replace
Posted on Mar 19, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Fridge side not cool and freezer side cooling like a fridge
Most likely a defrost problem. Are you sure your model is the model posted above your post? RS2630SH If not please let me know the correct model number. I have most of the manuals on the Samsung..............Sea Breeze
Posted on Jun 20, 2009
mgprice
Mike Price
  • 744 Answers
SOURCE: fridge/freezer cooling inefficiently
Either the repair guy did not wire up the heater correctly or he replaced the wrong part, if the heater was good it was likley to be the defrost thermostat...I would call the repair guy back to check.
Posted on Jun 23, 2009
snowycreek
  • 36 Answers
SOURCE: I have a GE side by side Fridg.that is approx
Setting the cooling setting up all the way will not help at all.Make sure your freezer and refrigerator controls are about the same setting. Temp. settings for refrigerator should be between 38-42.degree at medium.. Freezer about 0 to -10.If it is a simple fix this will help.
Posted on Feb 20, 2010
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Ge turbo cool fridge doesn't cool.
If your refrigerator is not cooling, the problem could be as simple as a covered vent or something more complicated that requires the help of a service professional.
Is your thermostat set incorrectly? It's possible to accidentally bump the thermostat, so check it and reset, if necessary, to the proper coolness.
If there's ice on the evaporator cover ( typically found on the back wall), it's a sign that the evaporator coils inside could also be covered in ice and frost, indicating a defrost problem. Try unplugging the fridge and defrosting it before calling for help.
Since you are hearing no unusual sounds, the problem could be the start relay, which triggers the compressor. Have a refrigerator repair pro determine if the start relay is the culprit and to replace it if necessary.
For more help identifying the causes and solutions, read Refrigerator not cooling or check out the video below. I hope this helps!
Sep 27, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not cooling, freezer seems to work fine.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | GE GSS20IEP Side by Side Refrigerator
Hi, our ge profile refrigerator is having temp
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Feb 24, 2010 | GE Profile¿ Arctica® Energy...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
421 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
