This is a champion gas engine compressor model number caers04.h6r5
SOURCE: compressor not cycling and building pressure after servicing
I would reset the low oil lever switch if it has one, common problem if you do not know it is there! check your owners manual.
SOURCE: champion compressor pops manifold relief on head
depends on what relief valve it is, if it is a 2 stage pump and it is the relief on the inner-stage that is lifting indicates the second stage is not pumping correctly! I would check for a broken valve. if it is the one on the discharge line to the tank, then something is restricting it, check for blockages in the line or in the check valve entering into the tank. Most important you isolate the compressor and drain all air pressure before you attempt any repairs
