Question about Technics SL-1200 Turntable
Distorted sound on Technics SL-1210 mk2
Hi there guys. This is going to be embarasing but well.. I don't know where to go. I just got myslelf Technics SL-1210 mk2 tuntable. I plugged it in, connected it to my hi fi... the sound was beautiful, apart from the buzzing sound. Obviously I didn't know what was causing it, I figured it must have been the wires. Soooo I decided to turn the deck around and ... screw it open, just to see whether the cinch cables are ok. I didn't mess about inside, just wantes to have a look, see whether they are ok. Didnt find anything unusual so put it back together and played it again... Now apart from buzzing sound I have a really distorted, discusting sound from my vinyls... I found out that buzzing sound was caused by the fact that my hifi couldn't cope with the strenght of the turntable and when I connected it through Numark mixer, the buzzing sound disappeared... Now my "only" concern is that distorted, awful sound when playing records. Has anyone got any idea what can be causing this?
Posted by pachwin on
Styluscity
    Champion:
  • Technics Expert
  • 271 Answers
Hi, check to make sure the headshell is fitted properly to the tone arm and that the stylus is not damaged. Cheers john. Styluscity
Posted on Nov 24, 2013
1 Related Answer
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: Distorted sound on Technics SL-1200/1210
You could be getting acoustic feedback from the speakers to the TT's. Lower the volume or somehow isolate them from room sounds and vibrations.
Posted on Jul 06, 2010
Technics 1210 mk2 humming
Hi, it needs to be earthed to your mixer or amp. Cheers john
Feb 03, 2013 | Technics SL-1200 Turntable
Jul 05, 2010 | Technics SL-1200 Turntable
He doesn't start anymore
I'm havin the same problem,
did u manage to work out what the fix is?
Dec 20, 2009 | Panasonic Technics SL-1210MK2 Turntable
Technics 1210 MK2 - unstable/uneven speed problem
Since this is a direct-drive turntable, it isn't a slipping or stretched belt. You will need a technician with a couple pieces of equipment and some experience/training to find the source of the problem. I suspect the part(s) will be the minor cost of the repair.
Sep 07, 2009 | Technics SL-1210 Turntable
Poor quality sound
Double check all your cables. The only 2 things that affect sound on the 1200s is the RCA cables and the tonearm. I would first replace the RCA cables to a better quality set.
- OPTiC
Technics Repair Videos
Technics Turntable Repair
DJ Equipment Sales
Technics Parts Sales
Jan 16, 2009 | Technics SL-1210 Turntable
1210 mk 2 pitch
Doubt it, ive heard of this problem before, usually people buying them second hand and the answer has always been get them repaired professionally, i dont know the reason for them doing it sorry.
Jun 10, 2008 | Technics SL-1210 Turntable
Technics sl 1210 will not start up
did you ever open the turntable. It sounds like the on/off switch is bad. Remove the platter and screws with a phillips screw driver and just make sure the connections are in place. make sure you disconnect the power first. let me know what happens afterwards.
May 24, 2008 | Technics SL-1210 Turntable
Technics sl 1210 MK2 does not start
Your switch probably went bad. Does it not respond at all? Does the button at least 'bounce' back when you press it? If not, then you might have messed something up when putting it back together.
- DJPROLAB
Feb 14, 2008 | Technics SL-1210 Turntable
1210 mk2 only playing through left speaker checked everything and needs new rca phono lead how easy is it to change thanks
If you have done some soldiering and have a steady hand, it's not difficult. If you are not sure, you could destroy that little circuit board that the lead runs to, and technics had discontinued production of that part. I'd say get it done by a pro with experience.
These guys are top notch:
http://www.repairnyc.com/
Hope this helps.
Jan 13, 2008 | Technics SL-1210 Turntable
Technics SL-1200 Turntable Logo
498 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
