RCA F19436 19" TV Logo
A
Anonymous Posted on Sep 26, 2012
Is the RCA F19436 digital ready - RCA F19436 19" TV
1 Related Answer
Anonymous
  • 375 Answers
  • Posted on Apr 16, 2008
SOURCE: Parental Control Code?
if you forgot your password you can reset it ,turn tv off press and hold vol< on tv and clear on the remote for 5 sec.,enter a new password next time you access the parental control menu.
I have an RCA HDTV 52" Rear Projection tv.. do
No they do not have digital tuners inside them. They are meant to be monitors to converter boxes, cable boxes, and satellite television receivers.
Is this TV digital ready
Any Tv is digital ready. But, does not have a converter. All you need is a Digital box to setup with your TV.. Hope this helps
1helpful
I recently acquired my grandmothers tv = an 2004 model RCA #27F350T and wondering if it is digitally ready for Feb. 19 - we are currently using an outdoor antenna with a booster.
I could not find a "RCA model #27F350T", but there is a RCA model 27F530T, and according to the users manual for that TV, it is not Digital ready. You will need a converter box if you wish to continue receiving antenna based broadcasts. Your users manual can be found at the following link.
http://tv.rca.com/RCATV/Assets/pdfs/27F530T_1620181B_IB_e-04.pdf
Convergence off on Digital Cable
convergence for the rca itc222 is set individually for digital and analog tuner. Most of time the set will have to be converge in service mode. as a tech i would not recommend getting intoservice mode. but the key is the the convergence has to be set indiviadually for each tuner. You could try autoconverging in digital or even manualy converging
1helpful
Sparking rabbit ears
If the fuse blows the instant the power is switched on, there is most likely a heavy short in the primary side of the power supply. This could be the rectifier diodes or the switching transistor (or IC). If you do not have experience identifying and replacing shorted semiconductors, allow a qualified tech to handle it for you.
Sound
It could be a defective speaker or the audio output IC could be bad also. If your not a tech its a good Idea to seek a pro in the repair of a tv set as there are no user serviceable parts inside these set. Good Luck
Set will not turn on
If you're NOT still under warrantee you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. good luck!
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
