Question about Visonik Car Audio & Video
Visonik vk 1000.2
Impedance
Posted by christi23071 on
Deciding which car stereo amp to purchase
Both amps driving their rated impedance will consume about the same amount of power. If you connect the amp designed for one ohm into a four ohm impedance load, it will output less power than designed and also use less power. If you connect the amp rated at 4 ohms into a one ohm impedance, it will output and use more power but at the risk of having it burn out since you are over driving the unit.
Jan 21, 2014 | Alpine Car Audio & Video
My visonik v700hc keeps going into protect modeafter listening for a couple minuits then will go green light then back to red after a coupke more any solutions
I suggest checking what ohm load you're presenting to that amp. go to www.the12volt.com and find the subwoofer wiring diagram and choosing the amount of subs you have on it and then the impedence of each one. you're probably sending too low of an ohm load to the amp this would cause it to go into protection quite frequently and eventually stay in protection.
May 30, 2010 | Visonik V700HC Car Audio Amplifier
Amp wont turn on..Visonik vb212pkw
Well you have a high impedance path to your amp. If you have an inline fuse that should have blown. Car batteries don't have a current limiting feature HA The only explanation would be that the amount of current passing through the wire is causing a large voltage drop due to a large impedance. What gauge wire are you using? Here is an example.
18 ft of 8 gauge wire would have to be passing about 400 Amps of DC current to yield a voltage drop of that magnitude. The wire would melt and all hell would break loose. So there has to be a break in your wire somewhere.
Dec 18, 2009 | Visonik VB212PKG Car Audio Amplifier
4000.1 soundstorm amp
Hello GregV24CHOPP,
The Soundstorm products are in about the same category as Boss, Visonik, Pyle, and Lanzar to name a few. Somewhere between overrated and definitely overpriced for the quality you get.
Look into the Alpine MRP-M1000. RMS = 1kW into 2ohms (600 into 4ohms), YES 4 OHMS(!), real power. No, it WON'T do one ohm. But most of those claiming to are not CEA2006 compliant anyway and can claim any power at any load and advertise for whatever buyers they can attract for their bottom-of-the-barrel products.
The MRP-M1000 is currently on sale at Crutchfield for only $347. Awesome power, and very good sound quality, too. I'm currently running 2 4ohm MTX Thunders off of "little brother", the MRP-M500, and they really shake the pavement.
You have to spend good money to get good power, there is no way around that.
The only wiring configurations for 2 2ohm DVC subs result in 0.5ohm, 2ohms, and 8ohms impedance. Check the Rockford-Fosgate "wiring wizard" for the different diagrams.
Hope this helps.
May 13, 2009 | Soundstorm CR4000.1 Car Amp
Smoke coming from visonik v4218
Generally, smoke means the power supply FETs have failed. There may be other problems that could have caused it to fail. It will need to be repaired.
Let me know if you have any other questions.
Aug 08, 2008 | Visonik V4218 Car Audio Amplifier
Installing visonik bass system
Here is a link to visonik to download manuals.
http://old.visonik.de/en/downloads.php
If you let me know your model number of the sub, vehicle make and model, and brand and model of headunit or CD player you have then i can provide wiring color codes, recommended wire routing locations, etc...
Jan 03, 2008 | Visonik 10" 500-Watt Single Bandpass...
What eq settings do i need
Hello ed4037, If you are blowing fuses this means that you are drawing too much current check your impedance value on your amplifier it should be 8 ohms to match the subwoofer's 8 ohms of impedance. In addition make sure that you have the proper value fuses. In other words you should not be tuning the amp not to blow fuses, because you should be able to go to full amplitude on your amp without blowing anything. As I alluded to this sounds like an impedance mismatch problem. I hope this helps, Thank you, Shuttle83
May 02, 2007 | Jl Audio 1000/1 Car Audio Amplifier
Visonik amps turn on into protection mode(where green not red for three days)...switched over the wires to some sony amps and they dont even turn the hell on
the fuze could be blown on the amp or the speakers are to much power for the amp at full power so try to turn the amp to half and not to turn the speakers all the way up,.
Jan 24, 2007 | Eclipse (XA1000) Car Audio Amplifier
Car Audio & Video Logo
Top Visonik Car Audio & Video Experts
xxxxxx xxx
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
