Xitel Inport De luxe with window 7
The user manuel gives how to use it with windows vista but not with windows 7. I need to know how to use it with windows 7
Posted by kouali78 on
  • Televison & ... Master
  • 6,102 Answers
The directions for using the Xitel Inport Deluxe under Win7 are the same as those for using the device with Vista. The drivers are built into the OS. You will need to set the audio input to the Xitel device. For most installs of Windows 7 (Aero capable), with the Inport Deluxe plugged into a USB port on the computer, click Start > Control Panel > Hardware and Sound. Under the Sound listing, click on Manage Audio Devices. In the Recording tab, right click on Microphone Input and select Disable. Right click on the Line INport and select Enable. Right click again on Line INPort and make this the default device. Click on the Playback tab and right click on Speakers INport and select Disable.
If Aero isn't available, it's Control Panel > Sound.
You can use any recording software that runs under your version of Windows 7. The LP Recorder software manual starts on page 8 of the Xitel Inport Deluxe manual. If you do not have the original disc, LP Recorder is available here: http://www.cfbsoftware.com/lprecorder/lprecorder.aspx . (Audacity, http://audacity.sourceforge.net/ , works much the same way as LP Recorder. However the drop down menus for the source and output are available from the main program with the default toolbars enabled.)
I hope this helps.
Posted on Sep 27, 2012
2 Related Answers
puertobori
  • 7733 Answers
SOURCE: I have an xitel INport that worked when I had
ZyXEL Support
Posted on Oct 27, 2010
Tony
  • 451 Answers
SOURCE: i need a software for windows 7 for xitel inport
INport - Windows 7 compatibility
Your INport Deluxe hardware and software is all Windows 7 compatible straight out of the box. Please click below to download the Windows 7 user manual addendum for instructions on how to install your INport Deluxe hardware.
http://www.xitel.com/USA/support_inport_vista.htm
Posted on Apr 08, 2011
I need a software for windows 7 for xitel inport
Apr 08, 2011 | Xitel INport (HFLI1X1) Audio Input
"Cant' find audio output mixer line for Line (USB Audio)(0047C6C0
I got this error when first running version 5 on Windows 7. So I tried running it in Windows XP SP3 compatibility mode, which solved it for me.
May 31, 2010 | Xitel INport (HFLI1X1) Audio Input
Need s registration key for xitel inport to put on my computer
I bought my'n from the home shopping channerl for $89.00
works excellent.
Feb 06, 2010 | Xitel INport (HFLI1X1) Audio Input
I lost ALL sound when Iinstalled Xitel's Inport
Have you trying to rollback using windows sistem restore
Aug 23, 2009 | Xitel INport Deluxe for PC
Lost registration code for xitel inport device
Most of the time the package of the CD the code was on it try to locate the code their else the email with do the rest.
Jul 07, 2009 | Xitel INport Deluxe
Audio
Try the solution at the Xitel site http://www.xitel.com/USA/support_inport.htm
Feb 17, 2008 | Xitel INport (HFLI1X1) Audio Input
Televison & Video Logo
363 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
