I have searched everywhere for an answer since my issue. Relevant info: - iPhone 3GS. - iTunes version 10.7.0.21 (2012-09-12). - Doesn't matter what system I have since this is related to an iPhone device. - Fully charged battery before proceeding with the update. - Updated the iOS 5.1.1 of the iPhone to iOS 6.0 through required update recommendation of iTunes. - Never been abused, jailbroken, serviced or dropped. (never had issues until the update) Once completed the updated process of iTunes and iPhone was done with the internal installation, the iPhone rebooted with a green screen/hue and the apple logo was still original color "silver". It loaded up to the iPhone Configure screen still with green color screen/hue. I pressed on the power button for 5 seconds and slide "slide to power off" and the iPhone turned off. I waited about 15 seconds and pressed on the power button to turn the iPhone back on, hoping no more green screen/hue and the apple logo was still original color "silver" but returned to the original green screen/hue and the apple logo was still original color "silver". Failed! It still showed green screen/hue and the apple logo was still original color "silver" and booted to the iPhone Configure screen still with green color screen/hue. Remedies tried after searching the internet: - Hard Restart/Reset. - DFU Mode. (even tried a restore process with iTunes again *so much time wasted to obtain the iOS download again* - Recovery Mode (even tried a restore process with iTunes again *so much time wasted to obtain the iOS download again* - Recovery from Backup is denied because previous version was iOS 5.1.1 and iTunes refuses the process so (even tried a restore process with iTunes again *so much time wasted to obtain the iOS download again* Left the iPhone at the Configure screen until battery drained and then plugged it back into the USB port of system until it charged long enough for the iPhone to boot yet again green screen/hue and the apple logo was still original color "silver". It booted to the iPhone Configure screen which is still the green screen/hue and I left it charging until battery icon top right showed full. Now, can someone give a straight answer while staying on this topic about this issue, please? *I can understand if the apple logo was green then it could be a screen issue but it is not the case. All help is greatly appreciated even if you took the time to read all of this but did not answer. Thank you! iPhone 3GS, iOS 6, green screen with apple logo
SOURCE: iPhone stuck on Startup logo
Reset the iPhone by holding the sleep/wake button at the top right of the device and the home button at the bottom center of the face at the same time. Hold them both until you see the screen go black and the white Apple logo appear. When this happens, you can let go - the iPhone is rebooting.
Resetting the iPhone should not remove or delete any data or settings.
SOURCE: my iphone wont turn on past the silver apple logo.
Open up iTunes, connect the iPhone. Hold down the power button for 3 seconds, hold both power button and home button for 10 seconds, release power button while still holding down the home button. This puts your iDevice into DFU mode, so it can be restored using iTunes.
SOURCE: update went wrong
If iPhone won't turn on, or the display freezes or doesn't respond
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: my iphone 2g is not charging and its not even syncing.
the place where you plug the wire might be messed up.. do a diagnosis on it with apple
there are many software
available to unlock iphone 3gs and my friend unlocked it by remote unlocking..there
are many online providers who provide the service..one of my friend got
unlocked his iphone 3gs from Mobileunlocksolutions by remote unlock..and here is the
instructions
1. Wait for an email saying your phone has been activated or
remotely unlocked.
2. Install the latest version of iTunes.
3. Make sure your Apple iPhone phone software is updated to
the latest version
using the iTunes software.
4. Connect your Apple iPhone to iTunes with a NOT ACCEPTED
SIM card.
5. Wait until iTunes detects your Apple iPhone.
6. Disconnect your Apple iPhone and reconnect it after 10
seconds.
7. Your Apple iPhone is now unlocked.
and the important thing remote unlocking is available for some country and network providers only so if you are interested you can try from them before that see whether remote unlocking is available for your country and provider..
