SOURCE: How can I remove write protection error from my flash though it hasn't any protection button?
Disengage the hold/lock switch
SOURCE: removing write protection of USB pen drive
if u format ur pen drive. then use this step
Check out the registry under:
1)click on start button
2)clik on run dialog box
3)type regedit
4) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0' and when you try to format it you have to format it as FAT16
Good Luck!!
Palwinder
SOURCE: how to remove write protection from flash disk
hi, i'm from indonesian i have a problem about flash disk USB2.0 1 gb. can u help me i have flash disk 1 gb to be 8 gb (not upgrade) it change it self "i don't know why & can't be to format & delete. i want to default be 1 gb to be a normally.
sorry of my bad english,,thank's
SOURCE: how can i remove write protection on my flash disk
YEA...UMM...I JUST FORMAT IT WITH THE PROGRAM THAT THE DUDE GAVE AT THE TOP..IT WORKS:s..IT DOESN;T MATTER IF IT HAS THE WRITE PROTECT OF NOT...IT JSUT ERASES EVERYTHING COMPLETE
OK – after an hour or so of faffing around :knock: , I think that I have found a possible solution . The problem seems to be something to do with Microsoft’s SP2 !
Here’s what worked for me (sorry for the Idiot’s Guide approach, but I used to :hotbounce hate it :hotbounce when I used forums and couldn’t understand what the technobabble meant!):
- Start > Run > type ‘regedit’ (without the speachmarks) > Enter
- Single-click on ‘My Computer’ > File > Export > save it to the Desktop (Always best to have a backup!!)
- Go to the following:
My ComputerHKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlStorageDeviceP olicies
*There seems to be some spaces here in 'StorageDevicePolicies' in the text above, there shouldn't be, OK*
- Double click on the string ‘WriteProtect’ and change the ‘Value Data’ box to ‘0’
- Then: File > Export > save somewhere useful as something like ‘StorageDevicePolicies001.reg’
- You also need to do this for the strings in any folders called ‘ControlSet***’ (* = any Digit, i.e. 001, 002) – for example: Everything is the same, just change ‘CurrentControlSet’ to ‘ControlSet***’
My ComputerHKEY_LOCAL_MACHINESYSTEMControlSet001ControlStorageDevicePolic ies
- Save these to the same place as before as ‘StorageDevicePolicies00*’
The saves are in case it reverts at a later date, just double click (saying ‘yes’ to importing these to the registry) on all of the files and it will all work again!
I hope that solves your Problem, If so kindly accept it.
Thank You,
Arjun.
SOURCE: REMOVE WRITE PROTECT FOR PENDRIVE
Try This Software .
easy to use .
click here :- http://rapidshare.com/files/271839302/Repair_v2.9.1.1.zip
Thanks
