Question about Omega Trane Furnace Draft Inducer Blower 115 Volt Variable Speed Fasco # A190
I need to replace the draft inducer Fasco A190, P/N C341445P01. It's $400! Is there a less expensive alternative?
The other reference number is 7000-5833. It is on a Trane furnace TUY080R9V3V. The circuit board on the original was charred and obviously bunt out.
Posted by Steve Texal on
Wayne Holden
  • 512 Answers
This is not a "tool" question, you should have posted to Air Conditioners.
eBay doesn't list any right now, last one went for $50.
Is it the control board or the fan or both that you need to replace? Might be able to find the control board separate if you have that number.
Best bet if you have the time, is eBay, Craigslist or a local heat and air repair guy who might have an old one he can sell you.
If you are lucky:
Ten-year internal functional parts limited warranty is effective on units installed after October 1, 2001 and manufactured January 1, 2000 or after. Earlier installations have two-year parts warranty
http://www.customengineering.info/products/esxv90.html
Posted on Oct 08, 2012
1 Related Answer
Thomas F. Schneider
  • 2715 Answers
SOURCE: Draft inducer blower going bad
I agree close enough. Only slightly slower. If it fits mechanically , useit.
Posted on Jan 17, 2009
Lighting the furnace pilot light. when I turn the gas to the on position the pilot light goes out
Well if you held the pilot knob down for 1 to 2 minutes before you turned it to on and it went out your thermocoupler is no good and needs replaced
Oct 21, 2013 | Omega Trane Furnace Draft Inducer Blower...
When I turn gas to furnace pilot light goes out
Now getting enough oxygen. To much fuel but it can not breathe try adjusting pilot nozzle.
Pilot light will not stay lit om furnace
No pilot feed or it is dirty and or cob webs may be disrupting flow. Clean every thing and relight.
Furnace won't stay lit
Are your air filters relatively new? Is a bird nesting in your units combustion air exhaust pipe? Does your draft inducer motor run before and after the gas has ignited? Check and confirm these 3 things first. Good Luck!
Mar 03, 2013 | Omega Trane Furnace Draft Inducer Blower...
Electrical diagram for contactor (240 v/1 phase/24 v coil)
How to connect motor 1 phase with mcb , contactor , timer ,switch selector on off on , and lamp indicator
Feb 17, 2012 | Omega Trane Furnace Draft Inducer Blower...
Jan 17, 2009 | Omega Trane Furnace Draft Inducer Blower...
Central heater will not heat up to set temp on thermostac
pressure port is plugged pull hose off draft motor and clean port with a paper clip
Jan 13, 2009 | Omega Trane Furnace Draft Inducer Blower...
Omega Trane Furnace Draft Inducer Blower 115 Volt Variable Speed Fasco # A190 Logo
1,390 people viewed this question
Top Omega Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you an Omega Tool and Hardware - Other Expert? Answer questions, earn points and help others
