The machine filled up and then stopped and wouldn't drain. I checked the hose and there was not a blockage, the machine started to drain as soon as I disconnected the hose from it. It appears that it didn't have enough power to push it all the way up the hose.
See this causes and fix it. God bless you
Drain Pump Filter
This is the most common problem. Some have a small cover in the lower
front put a screwdriver in the hole and turn counterclockwise to remove.
There will be a cover to remove, water will come out so be prepared
with a towel or wet vac. Clean this out. Other Machines will need to
access the drain pump to get to the filter. This can be done by removing the back panel on some washers. On others you will need to remove the lower panel or complete front panel depending on model. The filter is located inside the large hose from the tub to the pump. Remove the hose and clean filter.
Drain Pump
The drain pump may have failed. If you hear it making noises you will
need to remove the drain pump and check for obstructions, broken
impeller, or not spinning freely. Remove obstructions if it does not
spin freely replace the drain pump. If you hear it hum replace the pump if
nothing is found inside. If no noise is heard check the pump for power.
To do this remove the wire connectors and connect a voltmeter turn to a
drain cycle, refer to tech sheet or service manual for proper voltage
reading, usually any voltage would probally indicate a faulty pump. If
no voltage to the pump replace the main control board.
Hoses
Check the hoses from the pump by disconnecting them and make sure there
are no obstructions. Check your hoes drain, if it is a slow drain this
can cause your washer to not properly drain.
SOURCE: Wash Machine Drainage problem
i am a recently retired appliance engineer of 20 years, slowing down the flow of water from any electrical washing appliances can be dangerous and will cause extensive damage to the appliance in question, at the very least it will stop half way through the cycle every time the only way to remedy this is to rectify the drain, or at least sort out another waste water outlet sorry
SOURCE: Leak from pipe/wahing machine drain hose
try running the snake from the top to the bottom. they ell pressure hose ends that you inser into the pipe on the end of a hose and when you turn the water on it weslls and applies pressure to push out whatever is in there. they cost about 8.00 and you can buy them at lowes or home depot. just tell them what you need and that it screws onto the end of a hose for unclogging backed up drains. im not sure whats its called but they will know
SOURCE: My washing machine will not spin or drain,only fill up with water
Couple things could be happening;
Scenario 1: Your motor is dead, or the electrical connections leading to it are chewed up and no longer send electricity to the motor. If you have a voltage tester, you should see if you are getting power to it.
Scenario 2: The safety switch that stops the motor from spinning when the lid is open is compromised.. This is possible, but less likely, as the motor would still spin in agitate mode..
SOURCE: The washing machine stops during rinse and
Does it pump out the water? If it does then you have a broken drive coupler
If it won't pump out OR spin yall have either a bad lid switch
or loose lid hinge or broken strike.
Service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
