Question about Philips 50PFP5332 50" 1366 x 768 Plasma HDTV, HDMI, USB, ATSC
50" Philips Plasma 50pfp5332D/37 won't turn on
Worked perfectly last night. Today, will not turn on. Blue LED light on front of tv is glowing constantly, no blinks. No picture or sound. A series of 3 "clicks" emanates from the rear of the TV. These clicks are continuous if connected to power, so I have unplugged TV for hours and tried to re-set. Did not fix. Called Philips tech support - unhelpful - gave no ideas and was told to call a local tech or buy a new TV :-( Any ideas?
Posted by adrabick1 on
Rob Steinman
    New Friend:
I have a 42in vizio led with about the same problem i replaced a 75 cent chip # u33 on computer board problem fixed.
Posted on Sep 25, 2012
4 Related Answers
Anonymous
  • 4 Answers
SOURCE: 50PFP5332D Plasma tv. My tv sounds like its trying...
I have the same problem with my TV. I haven't verified this yet, but someone I know who's a electronics genius told me that its the buttons on the TV (power, channel, volume, etc.) He said at the factory many of the "button boards" were tightened too much and cracked. When you turn the TV on, the clicking noise is a loose connection. He said it's easy to replace yourself, and about 30 bucks on ebay. No promises though.
Posted on Sep 20, 2010
techman007
Lavell Turner
  • 1112 Answers
SOURCE: I HAVE A 50' PHILIPS
HI:
This is a plasma unit and philips plasma's are nortorious for bad power supplys, your problem may very well be the power suppy in the television, it is possible you blew a low B+ fuse on the power supply. There is also a issue with the Y-sustain board failing in this model, If you open the back and looking at the unit from the rear the y board is on the left side of the unit and the PS is in the center. disconnect the Y-sustain power plug from the power supply and turn on the unit if the unit stays on with no red light then the y board is bad. it does the same then replace the Power Supply.
Posted on Mar 10, 2011
Testimonial: "THANK YOU I WILL GET BACK WITH YOU AS SOON AS I TRY THIS"
jamie terzza
SOURCE: My Philips 50PFP5332D 50 in makes this clicking
its the capacitor inside the tv open it up and you should see atleast 1 capacitor which has bulged ( looks like glue coming out of it ) usually a 3000 ~ you can replace these yourself no problem for around 10p each but i do warn you there is a chance you could lose your built in freeview in doing so!
Posted on Nov 03, 2011
palaboy
Rommel Cana
  • 5807 Answers
SOURCE: philips 50pfp5332d/37 won't power on...led light blinks 4 slow, 6 fast...i can not find error code 46 anywhere
Error 46
Description Pacific 3
Detected by VIPER
Device T6TF4HFG
Error/ Prot E
These info are for qualified service technicians.
Posted on Sep 10, 2012
Samsung Plasma PN59D8000FF no picture no sound
Generally if the power lamp is on but the set is dead its the power board, you could remove the back if your comfortable doing so and check the voltages going from the power board and see if any are missing or incorrect...good luck!
Nov 25, 2017 | Samsung Televison & Video
I turn on my Mitsubishi WD-73833 TV and it turns itself off
Lessing of brightness on a DLP set is a sign of imminent bulb failure.
A new bulb is in order.
Nov 23, 2013 | Mitsubishi WD-73833 73" HDTV
Problem with Sony FD Trinitron WEGA KV-32HS510 32" TV
Blinking of standby LEDs to Sony TVs are fault indications. Form the number of blinks occur at one time, the repairman can get an idea of the faulty stage inside it. According to you, it blinks 4,6 & 7. Just visit this site, It has details about blinking codes to Sony TVs, both CRT based, Flat panels and Plasmas. I can't provide more advice to you, because the number of blinks are not constant. Check the site, and get it.
Jan 22, 2013 | Sony FD Trinitron WEGA KV-32HS510 32" TV
TV turns off by itself after 35 seconds of being on. Indicator light flashes red endlessly.
The TV is going into protection mode. Could be a problem with moisture. Can you try warming up the rear with a hair drier? Ensure that you do not apply too much heat to avoid damage to plastic parts. If you can remove the back cover (after unplugging the power outlet and switching off the TV), try doing in on the entire PCB, if you suspect moisture is the problem. Please do not touch anything in the board by bare hand as there would be high voltage charge in capacitors even after switch off. If it does not work, this might need attention of a qualified service technician
Jul 11, 2012 | LG 42LD450 42 in TV
Problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture...
Lets try an error code operational checl. Unplug the tv and plug it back in. With the standby LED on press and hold the MENU and DEVICE/INPUT buttons for 5 seconds. The LED will flash a certain number of times pause for a while and blink again. Count the blinks before and after the pass, then post it here so that I can tell you what the problem is
Mar 27, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
No Picture/No Sound
hello,
the 4 blink error I was assuming was a constant vs intermittent issue which is specific to ssb but based off the new information sounds like there was still an issue with the ssb as the firmware upgrade is specific also to ssb as microprocessor and eeprom are located on that board which stores that information. there is good probablility that the firmware was becoming corrupted with the intermittent issue and after the firmware upgrade must have become further corrupted and disabled the video and audio processing done on that board. it was logical to do the firmware upgrade though and no way to know that doing the upgrade would disable the set. hope this helps dan
Aug 15, 2008 | Televison & Video
Philips 50PFP5332 50" 1366 x 768 Plasma HDTV, HDMI, USB, ATSC Logo
1,084 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
