I have the docking station.
SOURCE: Transfer OZ-750 Data to Computer
Hi Pat,
and with the indulgence of otacon and Ekse...
You would need the Docking Module and the attached COM1 cable/plug.
You might find this page/document very informative if not interesting. Should you need the software (Day-Timer Organizer), it is available here. Additionally, a Q & A about OZ750 is here.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: Sharp OZ-630
Do an ALL RESET. The only way i know of to do it is to hold the ON and Reset at the same time. Then select yes at the promt. Then wait 2 mins and take out batteries. Reinsert and turn on. it will re-format. This is the only way i know of how to ressurect it, but it deletes ALL you data.
Thanks
SOURCE: Sharp Wizard OZ-770 working with Windows Vista
The www.wizardshop.net
can help you get it working with vista 32bit.
Go to www.thewizardshop.net and email or call them.
SOURCE: Syncronizing the data from a Sharp OZ-650 to a new computer
Just get a USB-to-Serial adapter and use the same method you used to use. Here's the one I ordered and it works fine. It includes a CD for loading a driver which I loaded before plugging anything in.
http://sewelldirect.com/usbtoserial.asp
SOURCE: Sharp OZ-730 sticky keys
I have a a Sharp yo-480. I've fixed sticky keys many times. I back-up data in the organizer first. (yo-480 doesn't have a flash memory) then carefully dissasemble unit. Lift out rubber keypad and use WD-40 to wipe circut board and keypad. It's the sticky residue that makes the keys stick
