Frigidaire 30" Built-In Single Electric Wall Oven Logo
A
Anonymous Posted on Sep 25, 2012
Frigidaire electric wall oven wont open error code f90
Put in self cleaning mode now it wont open and it gives trouble code f90
  • Official Brand Answer 4,342 Answers
  • Posted on Sep 26, 2012
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1466580
Points
5907
Error Code E90 typically means that you have a faulty motor door latch, lock motor assembly, door light switch or a defective EOC. You would need this to be diagnosed by a professional technician in order to properly repair the wall oven.
5 Related Answers
Anonymous
  • 883 Answers
  • Posted on Jun 01, 2007
SOURCE: gleb30tsa
find the circuit breaker panel and turn off the one labeled "oven". wait 30 minutes and restart. any luck?
Anonymous
  • 159 Answers
  • Posted on Jul 25, 2007
SOURCE: Frigidaire Electric oven model # GLEB27S7C
If you unplug the range and remove the lower rear cover on your left side you should see the motor with 2 switch's on it. There are 3 possibilitys with it. One of the switch's on the assembly is not working or the light switch for the door is not good. You also can disconect the lead to the motor and connect a power cord to it and that will unlock the door so you can check the dor switch also. if you do not feel comfortable powering up the lock motor then you should call a repair man. But one of the switches is not letting the computer know the dor is locked.
Anonymous
  • 523 Answers
  • Posted on Apr 24, 2010
SOURCE: Frigidaire self cleaning electric oven door will
un plug unit and put it back in self clean the cancle
Anonymous
  • 15935 Answers
  • Posted on Oct 01, 2010
SOURCE: my frigidaire gas range has a F90 on it when I
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Anonymous
  • 195 Answers
  • Posted on Dec 09, 2011
SOURCE: f11 error code - frigidaire electric overn
Disconnect power for 30 sec, then turn it back on
1helpful
F-90 error - self-cleaning ovn door will not lck and now light flashing and cannot use oven
Good Morning Nancy, I am happy to assist you!
If you are receiving error code F90, your maximum oven door unlock time has exceeded. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either flipping off the breaker or unplugging it for about ten minutes. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further since the unit may possibly have a faulty EOC (electronic oven control), lock motor assembly, door light switch or door latch assembly.
Best regards!
My frigidaire self cleaning oven says F90?
Lift top - there is a quater inch button on the black box behind the door lock - use screwdriver to press the button in - resets
3helpful
My frigidaire gas range has a F90 on it when I tried the self cleaning oven feature
unplug the range.
wait 1 minute.
wait 2 minutes.
1helpful
F90 code flashing and i cant reset it
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
1helpful
Oven went in self cleaning mode and shut off door unlocked f90 error code will not bake
During the cleaning cycle, there was a temp sensor malfunction that may have damaged the temp sensor. this is a common occurrence with this model. this is refereed to as a runaway temperature code. the sensor lost control of the cleaning cycle and it got to hot. the temp sensor is fried and it will need to be replaced.
3helpful
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Self Cleaning not working
What does it do when you put it into a self clean, any error codes, and have you ever used the self clean function before?
F93 error
F93 error code means Maximum oven door lock time exceeded. Check oven door lock/door lock switchs.hope this helps
Gleb30tsa
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
