Battery is dead and charger will not charge
First off, a Permobil C500 is not a PC laptop. Next time, please put this in the correct category.
Try charging up the battery/batteries with a auto car charger. Make sure the voltage is set correctly, and charge it on slow or low, 2Amps. Leave it on there for about 4 hours and see if the chair will run and for how long.
This should tell you if its the batteries or charger that's bad.
SOURCE: Battery will not charge when plugged in. 3rd blue
Hi, it might be one of the two.Sometime when a battery hangs, it might stop charging. what to do is to switch it off remove the battery and fix it back, then but it on again and see what happens.
You can also, try it out with another charger and another battery to sure of which really needs to be changed.
Hope it helps.
Take care and good luck.
SOURCE: i plug charger in and hav no led light to say charging battery nearly dead
If you have a Volt-ohm meter you can check if the AC adapter for your laptop is giving out the correct voltage. Also if you have a meter and you can see that the voltage is correct on the adapter try taking out the battery and plugging in the ac adapter and test the battery connection on the computer for voltage, if do have voltage to the adapter but not the battery terminal it could be a motherboard issue. A quick question, is the ac jack loose or does the plug move around easily when plugged in?
SOURCE: CHARGER NOT CHARGING BATTERY ON SAMSUNG N130 NETBOOK
Have you check the charger, is it providing proper voltage? it could be because charger if it is not supplying proper voltage to your laptop, if not then there use to a charging IC attach with the mother boardhas gone bad.
