Question about Denon AVR-2311CI 7.2 3D Home Theater Receiver
AVR-2311Ci display Display on front of the unit not working. The unit still works and can be setup through the on TV menu display. Is this a common issue/ repair?
Posted by G Fraser on
Dennis McCollum
  • 137 Answers
The display filaments which are the two outside pins will have 3-4 vac and the center pins should have around -25vdc on them if not check power supply
Posted on Feb 25, 2015
Rommel Cana
  • 5,807 Answers
Check the supply line and circuits to the display.
Could be cold solder joint, rectifier or capacitor.
check also if there are resistors in series.
Posted on Sep 25, 2012
4 Related Answers
ABRsvcs
  • 4234 Answers
SOURCE: Denon AVR-3802 Front Display problem
This can be either the display itself or the display driver IC havng problems. Something as simple as poor solder connections may cause this as well. Without seeing hte unit, it is difficult to say what the real problem is. If you can solder, try resoldering all of the voltage regulator ICs in the unit. These look like transistors and will be marked 7805 or 7812. If the voltages drift too low because of bad connections, the ICs can get "confused" and not work properly.
Keep us posted.
Dan
Posted on Aug 26, 2008
Anonymous
SOURCE: Unable to view setup menu on TV screen
I had this same experience and after hours of attepts to fix it (including the suggestions on this site) I found that the company that installed and set up my system literally disabled the "set up" on the remote so that it could not be changed. To fix this (and/or confirm that this may be your problem) reference page 39, "all reset functions" to reset your remote back to factory settings. As soon as I did this and hit "set-up" -- the set up menu popped up and worked appropriately. Hope this works for you!
Posted on Sep 28, 2008
Anonymous
SOURCE: On screen display does not appear
Same problem, thanks for the solution -- resetting power solved it.
Posted on Sep 30, 2008
EBC ELECTRONICS
  • 163 Answers
SOURCE: Display on Denon AVR-2307 won't work
1. Bad main transformer or
2. bad main fuse/ bad channel.
You need a repair shop.
Posted on Jan 22, 2009
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Jan 16, 2012 | Denon AVR-485 Receiver
How to reset the protector circuit in a Denon AVR 3801 unit?
14 INITIALIZATION OF THE MICROPROCESSOR
When the indication of the display is not normal or when the operation of the unit does not shows the reasonable result, the initialization of the
microprocessor is required by the following procedure.
1 Switch off the unit and remove the AC cord from the wall
outlet.
2 Hold the following AUTO button and PCM button, and plug
the AC cord into the outlet.
3 Check that the entire display is flashing with an interval of
about 1 second, and release your fingers from the 2 buttons
and the microprocessor will be initialized.
NOTES:
• If step 3 does not work, start over from step 1.
• If the microprocessor has been reset, all the button settings are
reset to the default values (the values set upon shipment from
the factory).
• Calling out preset stations from the main unit‘s panel.
1 Press the TUNING PRESET button. TUNING
PRESET
FUNCTION 2 Turn the FUNCTION knob and
select the desired station.
TV CD CDR/MD/TAPE RECEIVER
VCR DBS/CABLE
SKIP
SKIP
ENTER
MEMORY
CHANNEL VOLUME
VDP DVD
TUNER PHONO CD
DISPLAY
SETUP RETURN
MENU
SHIFT
SURR.
PARA. OSD
A/B
MUTING
BAND MODE
TUNING
TUNING
2 1
(Main unit)
Jun 11, 2010 | Denon AVR-3802 Receiver
How can I set to verify and set up my surround sound without the remote? Please help; can only hear cd player.
does the unit have a setup menu button on the front panel? if so push that, watch the display, use the up, down, left, right, select buttons on the panel to navi the menu. go online and look at a pdf user manual for the unit
Dec 07, 2009 | Denon AVR-3200 Receiver
No sound,no video,front panel display will display.harman kardon
Check your audio settings on the main menu of the receiver. The audio input should be set to "auto" Next, make sure you don't have the unit in "6 channel input" mode or "direct" mode. This is usually a small button on the front panel. If you check all this and you still have a problem, post a comment and I will help you troubleshoot some more. Hope this helps
Jun 30, 2009 | Harman Kardon AVR 140 Receiver
Cant Access System Setup on Denon AVR-588
Are you connected with video cables to a tv or "monitor" this is more than likely were the setup is visible for speaker configuration, input assignment etc, most denon receivers work this way so I would suspect you need to re-check the video connection until a set-up picture appears.
Feb 07, 2009 | Denon AVR588 Receiver
Denon AVR-3805 zone 2 no longer working
time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
Dec 29, 2008 | Denon AVR-3805 Receiver
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Dec 12, 2008 | Denon AVR-2800 Receiver
Keep us posted.
Dan
Aug 26, 2008 | Denon AVR-3802 Receiver
Denon AVR-2311CI 7.2 3D Home Theater Receiver Logo
144 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
