Spectroniq PLTV-42HW68 42 in. LCD TV Logo
Joyce Umbenour Posted on Sep 24, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Spectroniq PLTV-42HW68 TAKES 3 TO 5 MINUTES TO COME ON AND POPS THROUGH THE SPEAKERS SOMETIMES YOU GET SOUND BUT NO PICTURE, TURN SET OFF FOR 10 SECONDS SET COMES BACK ON AND PLAYS ALL DAY
Russ Hill
Level 3:
  • Spectroniq Master 4,057 Answers
  • Posted on Sep 18, 2013
 Russ Hill
Spectroniq Master
Level 3:
Answers
4057
Questions
10
Helped
1177503
Points
12696
Have you checked the capacitors check them on the power board look for a none flat top if any look like the tops have lifted up and gone rounded change them. also check the sound board for the same.
3 Related Answers
frankzcomput
Frank Zabroski
  • 268 Answers
  • Posted on Jun 19, 2009
SOURCE: Where can you get parts for a Spectroniq
There is only one person I know of that could help you with this
Frank Z. SR
Audio-Tronics
Cherry Hill NJ
Phone 8566670160
open 10-5 m-f 10-2s sun closed
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on May 30, 2010
SOURCE: changed power supply on my spectroniq pltv 3250.
Check the 3 fuses on the inverter bd.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
Inverer bd: www.shopjimmy.com
Anonymous
  • 126 Answers
  • Posted on Dec 03, 2010
SOURCE: I cannot find a remote control code that works to
Brand: Spectroniq
Most likely code: 11523
We have an lg 55 LH 40-UA.ACCVLJR that has sound but doesn't show the picture but says it is receiving no signal
basically it is input issue Brent, you may want to turn off and on your tv after 4-5 minutes, if same thing press on your tv remote INPUT, SOURCE or TV/VIDEO and you should have input lists on your tv screen. Choose one by one until you got a picture.
You can also check this out.
I decided to try the TV again, after it sat for the day. I plugged it back in, turned it on from the tv panel. It came on picture and sound was fine. Within 10 minutes, everything stopped, went blue. I did...
sounds like it is over heating. in side the tv there is 2 square box cannot remember the colour but they are yellow or blue near to a heat sink chip. if you change them it may just be that fault. Bush tv's suffer from this problem.
Spectroniq 42" LCD is dead - no power at all.
There is only one power supply module, see here: http://www.shopjimmy.com/catalogsearch/result/?q=PLTV-42HW68
Or try EBAY.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Picture no sound
Let verify first to narrow down to where the problem can be. First, check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
I have a 42 inch spectroniq tv, i moved over the weekend, so i unplugged the tv and when i plugged it up at my new house, i just get the sound with a blank screen
I have a Spectronic LCD HD 42 "color screen is black with bright colors, sometimes does not look good, it lacks definition to see.
Where can you get parts for a Spectroniq PLTV-42HW68, I need a main pcb board?
Frank Z. SR
Audio-Tronics
Cherry Hill NJ
Phone 8566670160
Top Spectroniq Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
