SOURCE: strange behavior
Initially, pls try disabling the hibernation feature of your computer.
Other than that, would appreciate if you can post back the make and model of your computer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: HP desktop monitor problem
hi try this ,,,
hope it will work for u .. little_angel
SOURCE: Windows XP won't start
The amber light is the error light on a Dell. It can mean a few things. 1. RAM has went bad, not properly seated. 2. Video card has went bad or come unseated. 3. Power supply is not working properly; or 4. Motherboard has went bad. Hope this helps & please remember to rate my answer.
SOURCE: Rebooting .. no effect on the monitor black blinking yellow light
Hi.
This is a hardware problem. If the machine seems to startup normally (apart from the monitor), then it is commonly caused by the video card coming loose. Turn it on, wait about 2 minutes until the drive activity dies down, then press the power button on the computer once. If the machine shuts down and turns off, then it had booted into windows normally and your data should all still be there. If you have a video card in the machine, unplug it, then re-seat it firmly and try again. If the machine is not booting (it doesn't shut down and turn off with a press of power), then unplug the RAM and the video card and press them back in firmly.
Mark
SOURCE: Can't turn Computer on. Green light on back flashing
I think there is a need of dusting the RAM and DIMM socket. Do the following steps:-
1. Open the cabinet
2. remove the RAM
3. Clean the DIMM socket(RAM socket)
4. Place the RAM again
5. Power on your computer.
