SOURCE: Furreal Pony neighs like a broken record
I had the exact same problem, and all I did was replace the batteries. It worked right again! I just knew the kids had broken the neck of it. It sort of slings to the left and neighs over and over again. BATTERY ISSUE :) The instruction manual should tell the consumer this. Hope this helps!
SOURCE: need help with the legss to move maybe need a command or manual
I don't think it is supposed to move at all
SOURCE: Hi, Where can I buy a new tail for my
Not sure where to buy a replacement but I just fixed mine today. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of plastic tubing with 1/4" inner diameter and 3/8" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the hole. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. The end of the tube with the hole should be just visible. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
SOURCE: Looking to repair the tail on Butterscotch pony
Had the same problem and the fix is easy. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of CLEAR plastic tubing with 3/16" inner diameter and 5/16" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the holes. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. You will probably need to twist the tube gently while applying firm pressure on it to make it slide over the stub. The end of the tube with the holes should be about even with the outside top of the white plastic hole and the tube holes should be level, looking at it from side to side. This makes the alignment of the screw hole to the tail correct. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully twist and remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right if you cut it too short! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
SOURCE: How do I reassemble the head of the FurReal Pony?
The Pony Care Guide refers to an "Assembly Video" on the FurRealFriends.com site. I couldn't find it and even went through a gazillion videos on YouTube. Contact Hasbro directly through this link to see if they can send you a link to the Assembly Video:
http://www.hasbro.com/customer-service/phone-directory.cfm
