Power light blinks 4 times
SOURCE: replacement table top stand for sony bravia 32
OK, Following is part number of Stand of KDL-32S3000 TV
A-1259-944-A STAND (M_WS) ASSEMBLY (KDL-26S3000/32S3000 ONLY)
It is available in Part Store.
Thanks.
SOURCE: sony bravia l42" LCD TV. No power. Green light on
7 blinks in the this series(KLV) means there is a short in the power supply board. The easiest way to fix this would be to swap out the board. I can find you a replacement if you want to try fixing this yourself.
Sai.
SOURCE: I have purchsed (Sony Bravia LCD KLV-32 bx300).
This is a protection circuit that prevents the tv from coming on (to stop damage of the components) ....you need to check your voltages off the power supply and make sure they all read well (EX: 24v12v5v etc). Also, look for popped capacitors that would make the values lower than need be for the tv to power on properly.
After you repair the power supply's capacitors you may need to replace other components if needed
BUT always start at the root of the problem (power supply) and work your way to other components
Please rate if this helps :)
SOURCE: power indicater blinks 6 times
"Backlight Error" and the possible location listed is "LCD Panel"
The "LCD Panel" includes the "Inverter MT board" and the "TCON control MT board". The part numbers depend on the serial number of your KDL32BX300. Only one of the inverter boards is available separate from the "LCD Panel". One of the "LCD Panel" assemblies is available for a cost of $518.45. If the serial number of your TV begins with a 5, you are in luck if you would like to replace the "LCD Panel".
Malfunction of 5V line
(Voltage Supply to FE, etc) please check 5v power supply other wise change
BG1TW MOUNT (KDL-32V4000)
main system board
