Http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp830?CMD=MIXED_SEARCH&mName=PIXMA+MP830&mType=PIXMA+MP&pageKeyCode=ekbresults&searchString=6A00&BASIC_SEARCH_CURRENT_TOPIC_ID=1067&BASIC_SEARCH_CURRENT_TOPIC_TYPE=0&RESULTS=RELEVANCE&RELEVANCE_START=1&RELEVANCE_COUNT=10&CONFIGURATION=1011&PARTITION_ID=1&TIMEZONE_OFFSET=null&USERTYPE=1&isSecure=false
SOURCE: Canon MP830 error code 6A00
The problem apparently is related to the purge unit located at the far right side on where the printhead moves back and forth.
there appears to be three common problems that causes the error, which is related to a paper jam error. 1) If its a new printer or even an older one, there are two sponges that collect ink and two plastic wipers located in purge unit may be loose or missing. Check to see if its it there. If not, it may actually be stuck somewhere.
2) there may some paper stuck somewhere around the printhead and or the purge unit or
3) there is a build up of gooey ink on the purge unit.
, I turned off the printer & unplugged it, move the printhead to the left and used long Qtips with Windex to clean up the ink around the purge unit including a little white plastic spring-loaded lever. also dampen the sponges with Windex. If you do this be careful not to dislodge the sponge or wipers. If you do, you can alway stick the pieces back in. After cleaning it, and checking the sponges and wipers are seated correctly, plug the unit back in and hopefully it will work fine. hope this helps.dont forget to rate as fixyaa
thanks and Godbless
HI,
Please the pixma off and open the lid.Now manually slide the cartridge-tray to the left.
Use a piece of tissue to clean the base-pad where the heads are
stored.See if it is stuck in a kind of upward position and look if the mechanism that moves the tray is released if not then touch it and it will be loose. Remove all ink residue, move the tray back to its most right position and close everything.
Let me know if you still get the same error.
Thank you
SOURCE: my canon mp830 had an error code 6500. I turned it
The 6500 error code is a logic board error code. Sounds like it needs new logic board assembly.
Testimonial: "Thank you cene765. I think my next printer will be an HP."
SOURCE: I have a canon mp830 error code 6a00.
That error means the purge assembly is jammed. Check for paper caught in the right side where the printhead parks, if all clear you will need a new purge assembly. A shop repair for sure....
SOURCE: Error Code 6A00, printer not working MP830
Move you ink heads out of the way and look inside, you will see the waste ink sponges and a little white plastic flap that may be jammed in position, wiggle it a little to free it and then continue to move it to make sure its free. This should solve it for you.
