Hyundai 2007 Sonata Logo
Posted on Sep 24, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Airbag light on 2007 hyundai sonata - Hyundai 2007 Sonata
Carmine Telli
Level 2:
New Friend:
  • Hyundai Expert 127 Answers
  • Posted on Sep 24, 2012
Carmine Telli
Hyundai Expert
Level 2:
New Friend:
Answers
127
Questions
0
Helped
24413
Points
356
Could be a pass seat reprogram. get codes scanned
How to Remove and Replace the Airbag on a Hyundai Sonata 2007
In order to remove and replace the airbags in your Hyundai Sonata you just have to follow these three following steps,
Step 1
Disconnect negative battery terminal. This is a must or you will trigger the airbag light on your dashboard.
Step 2
To remove the airbag from the steering wheel on Hyundai Sonata 2007, you will need to press three locking pins that hold the airbag in place. Use a Phillips screwdriver. A Torx screwdriver will work even better.
Step 3
Pull out the locking clips from the airbag connector. Then disconnect both wires from the airbag. You also need to disconnect the horn wire.
For more clarification, check out this video,
Bought a new mitsubishi mirage 2013 airbag light is on on dashboard why?
Hi Sandra, Have a diagnostic scan carried out on the vehicle. The usual problem is with the cassette unit mounted behind the steering wheel. Regards John
Airbag light is on, on my 2006 Hyundai Sonata
Has it ever been wrecked? Mine was and the shop that fixed it forgot to put the airbag sensor in the bumper...apparently this is needed to make the light go off...hope this helps.
My airbag lights inside my 2008 Hyundai Sonata want goes off do Advance Auto reset the fuses inside the car to turn off the airbag lights
No they can only check engine codes and by law they are not allowed to reset any ststems that have a malfunction. A airbag light will reset if the problem is corrected.
2answers
2006 Hyundai Sonata airbag light due to weight sensor problem. $1,400 part.... is there a less expensive solution.
ANY FAULT WITH AIRBAGS SYSTEM WILL COSTS ABOUT $1000.00 OR MORE THATS NOT A CHEAP FIX.
1helpful
2005 Hyundai Sonata airbag light just came on as I was driving along. Turned engine off and back on and the light was still on. Dealership wants $80.00 to diagnois. Is there a recall or does anyone know...
My airbag light stays on too. It could be a code you could just clear. The Sonata has several airbags. It could be a non working seat airbag, or even a thrown off senser (which is common in this car)! I dont think its worth 80 dollars to fix at the dealership. Go to auto parts store and get it checked.
1helpful
What a (!) light in dashboard means i have a 2007 sonata
this symbol is tire pressure, check them all and good luck
2answers
How to remove airbag light its staing on 2007 hyundai sonata
You can try disconnecting the battery for 30 minutes or so, then hooking it back up, but usually an airbag fault warning has to be actively reset with diagnostic software.
2helpful
Hyundai sonata brake lights
you will probably have to replace the bulb
2helpful
2007 Hyundia Sonata Brake Lights
There was recall for the 2006 and 2007 Hyundai Sonata Brake Light Switch assembly. www.promanuals.net
Top Hyundai Audio Players & Recorders Experts
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Hyundai Audio Player and Recorder Expert? Answer questions, earn points and help others
