This treadmill was recently moved, as far as I know nothing was damaged or banged. When we put it together and replugged in the wires the treadmill wouldn't turn on. So we checked the computer board and something was a bit loose so we fixed it, however when we pressed certain buttons like the stop or increase speed tthe power to the mother board **** off. When we press those buttons too hard it shuts off. We found if we kept a piece of metal in between the closure cover on the mother board it helped a little but when I press the buttons too hard it still shuts off. It feels like it may be grounding and or a wire may be loose. How can I get this problem fixed? Do I need to purchase parts? Thank You
SOURCE: Wiring diagram need for an Smoothfitness EVO treadmill.
Solved this problem by contacting the Evo/Smooth directly. Great service.
SOURCE: Proform 730i powers on but will not move when I input speed.
I have the same treadmill with the same problem statement. Here is how I fixed it:....Open the lower shroud that covers the motor. You must remove 4 or 5 screws. Taped to the inside of the shroud should be a document with a calibration procedure on one side and electrical specifications on the other. It will tell you how to run the calibrations. You need to hold the stop button and the + speed button as you insert the safety key. This will put you into calibration mode. My treadmill started working again after I ran the incline calibration routine. Hope this helps.
SOURCE: Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
SOURCE: Hi. I have a BH Explorer treadmill. We recently
By the sound of it I am assuming the you have power to the upper display. This happens quite often when people even moving their treadmill from one room to another. My suggestion is first make sure that the safety key is engaged on the upper electronics if it is then, unplug unit remove motor shroud then locate lower board and pull and reconnect each connectors then fire it up and observe if the LED lights are on one will say PWM. This is the command for the motor to engage, the light will start flickering this mean the upper console has sent the proper signal for the motor to move. If no movement then unplug unit then remove the two connectors that go to the motor attach a 18v dc (fully charged ) drill battery and if you the motor move then look at the lower board by sheer bad luck went bad . Now if you see no flickering on the lower board remove upper console and check the the connections their. hope this give you a directions to follow.
SOURCE: T3 - It slows down then speeds up, has mind of its own.
It sound like the Motor Control Board is failing call Life Fitness @ 1-800-351-3737 they will give you additional information and locate a servicer in your area
