Question about Makita 7 1/4" Circular Saw 5007NB
Changing blades on Makita 5007nb, blade won't lock down, flange and bolt bottom out, blade still loose.
I am hoping i only need to get a new flangs.
5 Related Answers
VtToolMan
Mark
  • 704 Answers
SOURCE: Unable to lift the saw blade Makita Miter Saw
Look at the pivot point on the rear of the miter saw for the push/pull locking pin. The pin is there so you can lock the saw in the down position for easier carrying. To unlock the saw, simply pull the locking pin out (Makita calls this the "stopper pin"). Then you can use the saw and easily raise and lower it for cutting.
As you might find it helpful to have, I have included a link from the Makita web site for a free copy of the owners manual that you can print or save for future use and reference. It has some handy info on use and care of your saw.
http://makita.com/en-us/Assets/images/Products/LS1030N/owners_manuals/LS1030N.pdf
Hope you find this Very Helpful and best regards!
Posted on Sep 20, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: how do I install the spring after changing the
what spring? do you mean the one in the guard? if so you don;t have to remove it to change the blade, give me the exact model number or you can go to makitatools.com and download a breakdown that shows the reassembly of the guard, it is not that hard, and also you can download an owners manual that shows the proper blade replacement procedure.
Posted on Jan 19, 2010
Anonymous
SOURCE: Makita Saw blade brake doesn't work.
i have a makita still saw put i pull cored but it dose'nt start
Posted on Jan 21, 2010
Anonymous
SOURCE: MAKITA DROPSAW MODEL 2400B HOW
There is a push-in lever located between the handle and saw blade.
Push in lever and rotate blade until blade locks.
Once blade is locked, loosen nut located in center of blade.'
Before removing blade, notice direction of teeth.
Install new blade with teeth going same direction.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 20, 2011
rowdy45176
David Ford
  • 2176 Answers
SOURCE: How do I assemble the blade guard for my Makita
lay the spring into the plastic safety cover, you will see a catch for one portion of the spring, the cover plate goes over it and there is a tab on it to catch the loose end and then the center plate which screws on to hold everything in place, check by turning the plate that holds it onto the saw for free movement. You can go to makitausa.com and in the header area on the right type in your model number ls1030n and you can download or look at a breakdown to see what I am talking about. Let me know if you need more assistance, just found your question.
Posted on May 04, 2011
1helpful
Makita slide compound- Saw Blade. LS0714
It seems as though the original blade was fitted without a spacer. These usually come with any new blade. It is simply a washer (usually aluminium) that fits in the hole of the saw blade and reduces the hole diameter down to the size of the flange on your saw. This is common practice. Never try and centre a blade without the correct size hole to flange size. Very dangerous. These washes are really cheap and can be obtained from most hardware stores. Usually in an assortment of different outside and inside diameters to suit any circumstance. Hope this helps, cheers Bob.
Oct 26, 2016 • Makita Saws
1helpful
How to change blade
Lock blade and undo the blade locking bolt in the direction of cut, normally anti clockwise if the blade is on the right. Lift guard and lift off blade. refit with new one insuring the bore size is correct. refit outer flange and bolt.
Jan 05, 2013 • Saws
How do u remove the blade on a chop saw ls1013
Be sure the saw is switched off and unplugged. Use the Makita socket wrench on the side of the saw base if you still have it. If not make sure you use a socket or wrench that fits the bolts properly so you get them off and back on without damaging them. Lock the handle in the up position with the stopper pin. Loosen the hex bolt holding the center cover in place, this will let you raise the guard and center cover so you can get at the blade bolt. There is a button on the back side of the blade guard that locks the spindle. Push and hold the button in and turn the blade until it locks in place. Using the socket wrench, turn the blade bolt clockwise or in the same direction the blade turns while cutting to remove it, the outer flange and blade. Put the new blade on (check that the direction of the arrow on the blade is the same as on the guard), the outer flange and blade bolt. Use the spindle lock to get the bolt on tight. Return the center cover to it's original position and tighten it's hex bolt. Turn the blade by hand to make sure the spindle lock released then pull the stopper pin and make sure the blade guard works properly.
Feb 03, 2012 • Saws
How do you change the blade on a Husqvarna partner K750 concrete saw?
The blade bolt is 13mm,on the opposite side there is a hole in the belt guard to insert a 6mm pin to lock the front pulley, once locked undo the blade bolt counter clockwise, once removed, remove the outer clamping flange, you can then remove the blade, the standard arbour is 20mm, this can be changed if you wish to a 25.4mm, or a 22mm, depending on the arbour size of the blade you wish to fit, the arbour just pulls off the shaft with a suitable puller. Refit the the blade and outer flange, tighten the bolt securley.
Jul 27, 2011 • Garden
1helpful
2answers
I bought a ls1016 coupond mitre saw this week. I was cutting cedar 2x6 's today and had a few kick backs. I am building my deck and do not feel safe using the saw after the kick backs. Why as this...
Sounds as if the blade is dull. Or perhaps bent. A dull or bent blade blade will 'grab' the wood, rather than cut it, resulting in binding, or kickbacks.
Solution; replace the blade with a fine-toothed, good quality blade. If the blade is new, then check that the blade is bolted tight on the arbor. If the blade is loose, it can result in kickbacks.
Also, check that all the bolts/fasteners/locking mechanisms on the saw are tight, and in good working order. Sometimes a tool new out-of-the-box will have loose screws/nuts/bolts that need to be tightened up.
Also, when cutting, use a smooth, slow, motion, being sure to give the saw the time it needs to make the cut.
2helpful
Replacing the blade on a Makita 255mm miter saw
I take it you have both flanges and the washer that is behind the innner flange, if not stop there and you need to get them. As far as the blade goes it depends on what size arbor it has. You would need to use the washer that goes on the spindle with no play (movement) and put the blade on the washer I would not use a washer that is thicker than the blade. Put the outer flange on making sure of the direction and then the blade bolt LH thread. Let me know if you have any problems before starting the saw PLEASE and I will help more.
Makita 7 1/4" Circular Saw 5007NB Logo
Top Makita Saws Experts
ray gallant
Parson's Repair...
Parson's Repair...
Are you a Makita Saw Expert? Answer questions, earn points and help others
