My c7 fone dont show airtel network , but on other fone it shows airtel network
No point contacting contacting airtel customer care, because your SIM card is working perfectly on different phone so I'd suggest you to reset your mobile phone once, that can fix the problem for you. If the issue is same, take your mobile phone to nearest Nokia service center.
SOURCE: My Nokia N72 shows no Network with any sim
it might b the problem in urs sim.
sir, when u can change ur sim then ur mob is showing the network.
becoz the problem in ur sim! not in mobile.
thnxxx
SOURCE: Insert sim card problem in Nokia 6030
nokia6030 mobil is not conecting the network its showing insert sim card
SOURCE: i bought nokia 6300 from dubai,now i am india but
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
You could ring the phone provider and ask for the unlock security code because you are going overseas and wish to use your phone with a prepaid SIM card from another country. This maybe a free service.
The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services. Use Google and search for "Security unlocking code” companies in your area.
You can also try this WEB site :-
http://www.mobileunlockguide.com/mobile-phone/
www.unlock-free.com/nokia-master
The IMEI number is unique the each mobile phone.
The number is printed on the label under the battery.
You can also get the IMEI number by entering this on your phone
*#06# It will then display your IMEI number and you may also get a unique global serial number. Your IMEI number should be 15 digits.
