Question about Motorola Mobility H730 Bluetooth Headset
How to open bluetooth headset motorola H730 to change the battery
I dropped my headset in pool and let it dry in sun. Then I recharged it. but I think I need another battery. How do I open the case to change the battery?
Posted by Jorge Pool on
Motorola Mobility
  • Official Brand Answer
  • 1,623 Answers
Jorge
The battery is not replaceable by consumerrs. Mark
Motorola Support
Posted on Jul 07, 2015
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Motorola HS850 Bluetooth headset
no u need to take it to phone manufactuer
Posted on Oct 08, 2007
Anonymous
SOURCE: Broke the ear hook for the Motorola h500 bluetooth headset
The ear hook on my H500 broke as well.  I called Motorola (866-289-6686) and they are mailing me a replacement.  Even though This bluetooth has a 1-year warranty.  I purchased mine in Jan. 2007 and was covered but the rep didn't verify anything regarding the purchase date so even if you're outside of your warranty, you might still give it a shot.
Posted on Oct 10, 2007
Anonymous
  • 2351 Answers
SOURCE: maual for Motorola H350 bluetooth headset
This may help. Click the link:
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/AU-EN/H350_User_Manual_19oct2007.pdf
Ignore the chinese as you go. Its like mixed together but you'll find what you need. Good day!
Please vote.......
Posted on Jan 17, 2008
Anonymous
  • 29 Answers
SOURCE: Motorola H550 Bluetooth Headset
Here is the user manual for the bluetooth headset.
User Manual
Pairing with the LG will be similar, your bluetooth settings will be under settings and tools, and either under "bluetooth" or "connections".
Posted on Jan 21, 2008
Anonymous
User Manual for the Motorola H350 Bluetooth headset!
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/H350_QSG.pdf
Posted on Aug 22, 2008
How to change battery on motorola h270 bluetooth headset
Pop it open and install new battery. $10 on eBay. Simple.
https://www.ebay.com/i/252284156183?chn=ps
Otherise: Headset is not functional while charging.
Note: This product uses a lithium ion, rechargeable,
non-replaceable battery. Under normal use, the expected life of the rechargeable battery is approximately 400 charges.
There should be a seam around the headset where you can insert a fingernail or a small screwdriver to pry the case apart. I would try to open the case before you buy a new battery, because if you pop it open and break it, you haven't lost anything cause it's a one-shot deal anyways.
This isn't the same exact earphone, but the procedure to open it may be similar.
https://www.youtube.com/watch?v=-Nby71f3MtI
Good Luck!
Dec 14, 2017 | Motorola Radio Communications
How long should i charge the headset and how to turn it on
The headset contains a lithium ion rechargeable battery, which should be charged before using the headset for the first time.
System requirements for battery charge using USB
Personal Computer with pre-installed with any of the following operating systems and USB port:
Operating Systems (when using Windows)
Windows® 7
Home Basic / Home Premium / Professional / Ultimate
Windows Vista® (Service Pack 2 or later)
Home Basic / Home Premium / Business / Ultimate
Windows® XP (Service Pack 3 or later)
Home Edition / Professional / Media Center Edition 2004 / Media Center Edition 2005
(when using Macintosh)
Mac OS X (version.10.3 or later)
Charging the headset
  1. Open the cover of the micro-USB port.
Insert the tip of your fingernail in the groove, and open the cover.
  1. Connect the supplied micro-USB cable to the headset, and then connect the other end to a computer.
Make sure that you connect the plug of the micro-USB cable in the direction as shown in the illustration below.
Charging starts when the headset and the computer are connected.
Make sure that the indicator (red) lights up. Charging is completed in about 6 hours* and the indicator (red) goes off automatically.
*Time required to charge the empty battery to its full capacity
Notes
  • If the headset is not used for a long time, the indicator (red) may not light up when you connect the micro-USB cable to charge the headset. In this case, do not disconnect the micro-USB cable from the headset and wait until the indicator (red) lights up.
  • When you close the cover of the micro-USB port after charging the battery, push the catch at the edge (the round part) of the cover into the port compartment.
  1. Catch
Tips
  • If the micro-USB cable is connected to a computer while the headset is turned on, the headset will be turned off automatically.
  • To charge the headset from an AC outlet, use USB Charging AC Power Adaptor* (sold separately). For details, refer to the manuals supplied with the USB Charging AC Power Adaptor.
  • The headset cannot be turned on while charging the battery.
*Refer to the Reference Guide on the recommended adapter.
Caution
If the headset detects a problem while charging, the indicator (red) may turn off, although charging is not complete.
Check for the following causes:
  • Ambient temperature exceeds the range of 5 °C - 35 °C (41 °F - 95 °F).
  • There is a problem with the battery.
    In this case, charge again within the above-mentioned temperature range. If the problem persists, consult your nearest Sony dealer.
Notes
  • If the headset is not used for a long time, the battery may be quickly depleted, however, after a few recharges, the battery life will improve.
  • Even if you do not intend to use the headset for a long time, charge the battery to its full capacity once every 6 months to maintain its performance.
  • If the headset is not used for a long time, it may take longer to charge the battery.
  • If the life of the built-in rechargeable battery drops to half the normal length, the battery should be replaced. Consult your nearest Sony dealer for replacement of the rechargeable battery.
  • Avoid exposure to temperature extremes, direct sunlight, moisture, sand, dust or mechanical shock. Never leave the headset in a car parked in the sun.
  • If the computer enters into hibernation mode while connected to the headset, charging will not be completed properly. Check the setting of the computer before charging. The indicator (red) will go off automatically even if the computer enters into hibernation mode. Charge the headset again in this case.
  • Use the supplied micro-USB cable only, and connect directly to a computer. Charging will not be completed properly by an indirect connection, such as via a USB hub.
Usage hours
Status Approx. usage hours Communication time (including music playback time) (up to) 30 hours Standby time (up to) 200 hours The communication time will be about 15 hours when it is charged for 2 hours.
Time stated above may vary, depending on ambient temperature or conditions of use.
Checking the remaining battery
If you press the POWER button while the headset is turned on, the indicator (red) flashes. You can check the remaining battery by the number of times the indicator (red) flashes. The indicator (red) flashes immediately after the headset is turned on to indicate the remaining battery power.
Indicator (red) Status 3 times Full 2 times Mid 1 time Low (needs to charge) Note
  • You cannot check the remaining battery during pairing operation.
When the battery is almost empty The indicator turns red. When the battery becomes empty, the headset sounds a beep and turns off automatically.
Mar 26, 2016 | Jabra Bt2045 Bluetooth Headset
Samsung s4 has been dropped in water all dried and seems fine but it thinks its in headset mode
Could be there is still moisture inside the headset socket .insert headphone jack into it and the keep drying the input end to see if this cures it.really need to dry this phone out over a week with the battery out as condensation from body heat will keep occurring if any moisture remains.
Jan 19, 2015 | Samsung Cell Phones
My phone was in my pocket when i jumped into the pool .. how do i dry it out ??
remove the battery and keep in dry place where sun shine is there for 1 hr remember to cover the lcd part with a blck cloth and rest all to be exposed to sun remove sim and mem card and battery
Jun 27, 2011 | Audio Players & Recorders
I dropped my phone in a pool and i took the battery out right away and let it sun dry for 2 hours then i set it in rice for over night what shall i do next I NEED HELP.
Blow into it with your hairdryer without heat. Do it for a minute or so many times to remove water traces from the insides. Do not put the heat on else it may get toasted.
Aug 02, 2009 | Cell Phones
KX-TG5632 fell into the swimming pool. Can it be fixed?
soak in rubbing alcohol and let dry for a couple of days shake out excess alcohol and make sure(take out battery first)is completly dry before recharging!!!! Good Luck!!! had cell phone drop in lake did that and worked!!!
Jun 24, 2009 | Panasonic KX-TG5632 Phone
Phone went for a swim
Another way of completely drying the phone is to put it in a bag with some rice, rice absorbs all moisture...
May 18, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Liquid Damage + Removing Motherboard Instructions
I dropped my phone in the sink while washing up, I dried it out but the phone continously kept switching self off, I though it was the phone. I borrowed a collegues battery and the phone worked it din't switch off once. So i bought a new battery and it works perfectly since.
Dec 25, 2006 | Motorola Mobility RAZR V3i SLVR L7 L8 OEM...
Motorola Mobility H730 Bluetooth Headset Logo
1,633 people viewed this question
Top Motorola Mobility Radio Communications Experts
JonSnell Electronic
JonSnell Electronic
George Scott
George Scott
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
