I need adaptor cable for FPD 1530 to connect to dell cpu The supplied cable will NOT connect to the monitor port on my computer - it does not fit, cannot be connected
This should be the adapter that you need, DVI to VGA.
http://www.ccl-la.com/catalog/product_info.php?cPath=83_87&products_id=130
SOURCE: Monitor comes on and then turns off
You can have shorted out transistors, transformers, bad lamp assembly (this one will be hard to test if you do not have the tester).
Please send me pictures of the board so I may be able to point out where to test. [email protected]
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
SOURCE: Blinking green light with no display
Have you tried connecting this monitor to another computer?
Have you tried resetting the BIOS? That should reset any problem the video driver for the monitor maybe facing.
SOURCE: My monitor will not stay on. Gateway FPD 1530 15 in.
The Inverter Board needs to be replaced. (Easy to repair)
SOURCE: cable for Gateway FPD 1520 15in. flat screen monitor
live in remote area of Nevada were can i find power cable for FPD1529 monitor???
SOURCE: can't go higher than 640x480 resolution
Go to device manager-> expand display adapters. Rightclick on the video adaptor and select properties. Click on driver tab and select option RollBAck driver.
